Driver's Side Door Latch
Old Mar 14, 2024 | 12:58 PM
R-Banger's Avatar
R-Banger
Hi there everyone,
Been working through trying to sort out why I can't open the door from the inside. So I replaced the interior handle latch assembly, checked the linkages and they are al solid. With the door apart, I can close the door and pull the interior handle all the way and it won't open from the inside. If I grab the linkage by hand and give it an extra 1/8" nudge the latch then functions properly. Looking at it and comparing to my passenger side one it seems like the visible spring on the latch assembly is snapped completely in half so it is not working. I have scoured online and called Dennis Carpenter to see if anyone makes a replacement latch. Has anyone had luck finding a replacement latch or getting the current one repaired/restored? Thanks in advance.
Old Mar 14, 2024 | 03:19 PM
silverflash's Avatar
silverflash
Please forgive my lack of expertise, are you looking for the mechanism that is activated by the interior handle or are you talking about the door latch assembly that latches onto the door striker bolt?
Old Mar 14, 2024 | 04:01 PM
R-Banger's Avatar
R-Banger
The latch assembly that latches onto the door striker bolt.
Old Mar 24, 2024 | 06:47 PM
R-Banger's Avatar
R-Banger
Bumping to the top.
Old Mar 24, 2024 | 11:35 PM
Green72F250's Avatar
Green72F250
Not sure if this is the same issue, but this thread shows how this member made his own replacement spring for the door latch assembly:
1968 F100 door latch spring? - Ford Truck Enthusiasts Forums (ford-trucks.com)
Johana924
2015 + Expedition & Navigator
Jun 3, 2021 11:02 AM
lemonslg
Mar 4, 2021 08:42 AM
hillcountryflt
Nov 30, 2014 12:33 PM
pauldfixr
Aerostar
Jan 27, 2008 03:04 PM
Heavenword1
Aerostar
Jan 31, 2007 11:36 AM
