Sponsored by: Real Truck
Starter relay problem 2015 SD
Old Mar 11, 2024 | 01:12 PM
olderford76's Avatar
olderford76
8th Gear
This is a problem that I have been baffled about, progreivly getting worse . I have to cycle the key run, start , run, start ... At first it was just a couple times now sometimes it's 20 times, I have changed the ignition switch and had a couple shops look at it ... They had no clue , starts every time, first crank after the first time
Old Mar 13, 2024 | 07:16 AM
runthatjunk's Avatar
runthatjunk
Assuming you mean it won't crank when it's supposed to. First verify all connections then verify voltages at starter while in the start position.
Old Mar 13, 2024 | 07:26 AM
CFLSuperDuty's Avatar
CFLSuperDuty
4wd Low
This issue could be within the BCM (Body Control Module), I had this issue and got worse over time, the BCM was bad. The BCM is the fused module located on the passenger side behind the lower kick panel. If you have a tool to check for errors when plugged into the trucks data port, as the issue happens you will see an error or failure within the BCM module.
Old Mar 13, 2024 | 11:35 PM
olderford76
8th Gear
Bad starter solenoid
Thanks for the things to look for, I will check them when I get a minute and let you know what I find
.... So a few tests and found out the starter solenoid relay to be the culprit, put on a new starter and cranks as soon as I hit the key.
Again thank you all for the input and info
Last edited by olderford76; Mar 18, 2024 at 09:59 AM. Reason: Update problem found
dgrant09
Modular V10 (6.8l)
Aug 18, 2020 07:46 AM
kboughton
2004 - 2008 F150
Feb 2, 2017 10:08 AM
shaun327
Aerostar
Aug 6, 2003 02:10 PM
KJKozak2
Oct 20, 2002 01:38 PM
