Sporadic starting issue
Old Jan 24, 2017 | 12:04 PM
kboughton's Avatar
kboughton
Hello all...I'm having a very sporadic starting issue that I need some help with.
In the last 50 starts it has happened twice:
When I try to start the truck, all dash lights and power come on but there is no sound or cranking from the engine. If I cycle the key back and forth a half a dozen times it will then crank and start. Next time I will try and listen to hear if the solenoid is clicking.
I've read posts about it being the anti-theft, ignition switch, stater relay, ppm relay, etc....
I could replace the relays to rule them out, but my gut is telling me that's not it? Would there be a code from something like this?
Thanks
Old Jan 24, 2017 | 03:52 PM
46fordtruck's Avatar
46fordtruck
My GF's Focus did this exact same thing 2 weeks ago. The only way to to get it start was turning the key over and over. No clicking at all from starter relay. I replaced the starter, no problems since then. It might be the relay, and not start itself, but figured I would have to pull starter to get the relay off, might as well replace the whole deal since it's the original '00 starter.
Old Jan 24, 2017 | 04:42 PM
pdqford's Avatar
pdqford
When it fails to crank, shift to neutral and try to crank it.
Old Jan 26, 2017 | 12:08 PM
1saxman's Avatar
1saxman
Solenoid, ignition switch, neutral safety switch (on transmission) are the 'big three'. Like ford said, shift to Neutral and try it. You might have to be an octopus or get help, but hold the key on Start and slowly shift the trans from Park to Neutral back and forth to see if you get a hit.
Old Jan 26, 2017 | 11:44 PM
kboughton's Avatar
kboughton
Ok, thanks. I'll give it a try and update once it happens again. At this point it's sporadic.
Old Feb 2, 2017 | 10:08 AM
kboughton's Avatar
kboughton
I recently cleaned the connections (3 wires) at the starter/solenoid and the battery terminals. All is good so far, did I get lucky?! I'll repost in a few weeks to see how it goes.
jlw247
May 26, 2015 08:15 AM
dangerranger10
1983 - 2012 Ranger & B-Series
Aug 11, 2011 09:07 PM
moarkmike
Jul 28, 2010 04:58 PM
dbrasier
Sep 29, 2004 11:18 AM
shaun327
Aerostar
Aug 6, 2003 02:10 PM
