Modular V10 (6.8l)
2001, Intermittent Starting Issue
Old Aug 11, 2020 | 06:50 PM
dgrant09's Avatar
dgrant09
Hi,
We have a 2001 F-53 chassis with a 6.8L, for a 2002 motorhome. We have seemed too developed an intermittent starting issue. When the key is turned to start, everything comes on the dash, lights, etc, but the engine does not crank over. I do not even hear a click. The battery is relatively new with a great charge, clean posts, cables are fine, starter relay and starter are new. If it would do this again, I could check voltage at the relay from the ignition switch, but, as I mentioned, it is very intermittent and the intervals are spaced far apart. Would I be correct in guessing that the ignition switch could be failing?
Thank you for your input and time,
Daniel
Old Aug 12, 2020 | 06:12 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
What finally gets it to start? Just waiting, or by trying the key a few times?
Old Aug 12, 2020 | 07:55 AM
dgrant09's Avatar
dgrant09
The first time this happened, we were parked in a poor spot to leave the coach parked. I cycled the key numerous times and nothing. Then replaced the start relay, nothing, then the starter, which worked for several days. Yesterday, it happened again, cycling the key numerous times, it finally started and has been fine since.
Old Aug 12, 2020 | 10:46 AM
krewat's Avatar
krewat
When you say relay, do you mean the big one on the passenger fenderwell, that some would call a "solenoid"? Certain years of trucks had them, and some did not. My 2001 did.
I think there is a relay somewhere before that solenoid which also may be faulty.
Old Aug 12, 2020 | 01:41 PM
dgrant09's Avatar
dgrant09
When I mention the starter relay, that is in the passenger wheel well area. The solenoid is part of the starter unit itself. I hope I am correct with the naming of these. Bother the relay and starter, with the solenoid were replaced.
Old Aug 12, 2020 | 04:08 PM
krewat's Avatar
krewat
You are correct in those terms, but some people call that big thing on the wheel well a "solenoid".
I still think there is a relay before that big relay. Hang on...
Old Aug 12, 2020 | 04:16 PM
krewat's Avatar
krewat
I just realized, there is no other relay, BUT - there is the DTRS - The transmission range sensor. Hmm... jiggle the handle next time
Old Aug 12, 2020 | 04:18 PM
krewat's Avatar
krewat
More to the point, the previous was F-Superduty, this one is F-53 (motorhome):
Old Aug 13, 2020 | 12:50 PM
dgrant09's Avatar
dgrant09
Thanks Krewat. With this schematic I felt confident on the switch so I replaced it last night and thus far no issues.. The coach was acting up before the replacement so it appears as if this did fix it.
Thanks again to all for your input.
Daniel.
Old Aug 13, 2020 | 02:34 PM
krewat's Avatar
krewat
And thank YOU for reporting back
If it ever happens again, I'd concentrate on the transmission shifter sensor (DTRS). Both the sensor, and it's connector.
Enjoy !
Old Aug 18, 2020 | 07:46 AM
dgrant09's Avatar
dgrant09
Thank you Krewat - we'll do..
phil64
Oct 6, 2019 12:29 PM
Rich Davis
1997 - 2003 F150
Nov 30, 2015 10:50 AM
Estes9294
Jul 1, 2014 03:02 AM
dangerranger10
1983 - 2012 Ranger & B-Series
Aug 11, 2011 09:07 PM
Spragga
1978 - 1996 Big Bronco
Nov 30, 2003 03:03 AM
