big black ac box
Old Mar 10, 2024 | 11:13 PM
K9Kodi's Avatar
K9Kodi
big black ac box
i've already started removing my broken ac.
i've got the lines off and the compressor unhooked. there is a large black box mounted to the firewall on passenger side, if i remove that will it effect the operation of my heater?
Old Mar 11, 2024 | 05:49 AM
Olds64's Avatar
Olds64
Yes, the black box on the passenger's side of your firewall contains the heater core and AC evaporator. If you remove everything you'll no longer have a heater core.
Old Mar 11, 2024 | 05:57 AM
K9Kodi's Avatar
K9Kodi
no good i guess it will stay. i can remove the ac lines going to
it though right. just keep
heater lines from mktor
Old Mar 11, 2024 | 07:11 AM
FuzzFace2's Avatar
FuzzFace2
I would say yes just seal there the evap coil lines come out so air only goes inside the truck.
I think DaveF said the 87-92? trucks with out AC will have a box you can use to replace yours.
Thing is your firewall has 3 larger holes and non AC trucks only have 2.
Some of the smaller holes are moved also but they are not a big deal they say.
The newer trucks the fire walls are all AC and the box changes to make it non AC and why it will bolt to your fire wall.
No I have not dont this just going by what I seen posted.
Me I wanted AC in my non AC truck so I graphed in half of the AC fire wall into my truck for factory AC.
non AC
Dave ----
Old Mar 11, 2024 | 12:33 PM
kr98664's Avatar
kr98664
That big black box (under the hood) houses the AC evaporator and is also the duct between the fan and heater core. On factory AC trucks, the heater core is inside the cab. If you were to remove that box, all airflow from the fan would simply dump under the hood and never reach the heater core or cab.
You could safely remove the evaporator from inside the box but it might not gain much for you. The evaporator face typically collects debris that eventually forms a hard mud and restricts airflow. (All airflow passes through the evaporator even if the AC is off or not working.)
The case is easy enough to open. Undo the fasteners around the perimeter. One fastener passes through the firewall and is accessed from inside the cab, above the passenger’s feet. With the case open and lines removed, the evaporator pops out. You’d have to plug the holes for the lines.
Old Mar 11, 2024 | 12:41 PM
K9Kodi's Avatar
K9Kodi
so on an old *** truck like mine, i may improve heater and defrost flow by removing the box, taking out the evaporator core and simply using the box as a duct line for the blower motor
Old Mar 11, 2024 | 03:04 PM
Franklin2's Avatar
Franklin2
Yes, you can see an improvement, the A/C coil used to sweat when it worked, and then dirt would stick to it and clog it up.
Jeff Wecker
Mar 14, 2024 09:44 PM
Welowright
Apr 10, 2017 09:51 PM
Rusty_S
15
Mar 30, 2017 06:37 PM
Triggh4
Oct 14, 2012 12:33 PM
emgee
May 10, 2009 11:57 AM
