Manual Locking Hubs Usage Questions
Old Mar 13, 2024 | 06:17 PM
AuroraGirl's Avatar
AuroraGirl
Originally Posted by 94ZR580
I believe the modern trucks do not unlock the hubs. The switch on the dash just controls the transfer case and the front dif spins all the time. The primary difference would be that most front axles now-a-days are CV joints, especially in IFS front ends, which don't bind up like cardan (u-joint) steering axles can. I think the manual hub systems are supposed to be tougher and they are simpler, which should be more reliable and less maintenance. If the rear dif can spin at 80 MPH on the highway, why wouldn't the front handle it, too?
sometimes the front differential shouldnt spin as much because it will incur more wear. Driving in 4x4 with a low pinion front axle will wear the coast side of the gears while driving. But i imagine a low pinion front axle being driven by the road(locked front hubs without 4x4 engaged) probably handles that better wear wise. Neither being driven, such as unlocked front hubs, wears even less!!
Old Mar 13, 2024 | 06:22 PM
Mudsport96's Avatar
Mudsport96
Usually one side is disengaged, typically it is the passenger side that actuates to fully engage the front end. This way you dont experience the binding of awd and reduce wear.
Old Mar 18, 2024 | 04:29 AM
wannabuyaford's Avatar
wannabuyaford
Originally Posted by Nothing Special
My rule of thumb is to lock the hubs before I start out if I think I might need 4WD and unlock them when I know I won't. On rare occasions that ends up meaning I have my hubs locked for days at a time. Which is fine. But for the most part I don't tend to need 4WD for longer than a day or two at most, so I unlock the hubs to reduce wear slightly, improve mileage slightly and eliminate the slight vibration in sharp turns.
If I needed 4wd day-in and day-out I'd leave the hubs locked for long periods. But I don't need it that much.
Do you even do that if you're driving 70-80mph most of the time? That's the only way to drive where I am, not sure if I need to get out and unlock/relock every day?
Old Mar 18, 2024 | 04:56 AM
AuroraGirl's Avatar
AuroraGirl
iirc the transfer cases in these trucks want you to stay 55 or under
But I could be thinking of square body chevys. I have gone 80 in my gmt800 (Np261 case) in snow and its definitely something it doesnt like
Old Mar 18, 2024 | 06:03 AM
TooManyMIce's Avatar
TooManyMIce
Reduced wear and tear is a nice perk of locking hubs, but many vehicles hold up just fine without. The main purpose IMO is fuel economy. The truck rolls a little easier when it's not turning the joints, diff, and front driveshaft, so it uses a little less fuel. Unless TTB is somehow different from any other 4x4 I've worked with, or yours is badly worn/damaged, or your front diff is welded, I would not expect any trouble from driving at highway speed with the hubs locked.
I don't think I've seen a speed rating for just the hubs, but I have seen one for when 4x4 is engaged--likely because you shouldn't be going highway speed if it's too slippery to make it in 2WD.
Old Mar 20, 2024 | 01:16 AM
wannabuyaford
Originally Posted by tjc transport
I rarely drive over 55
Okay thanks anyway. Man. After all of this I'm still at square 1 with this question.
Old Mar 20, 2024 | 10:40 AM
Mudsport96's Avatar
Mudsport96
Okay, let's make this easy.
When was the last time that you had the hubs off and serviced the front wheel bearings?
As in removed the bearings and repacked or even replaced them, checked the through spindle stub shaft bearing to make sure it is in good shape and not eating the stub shaft?
Checked the out axle u joints for grease?
At this point the truck is 28 years old, if you can not definitively answer " last summer, 3 summers ago, or 10,000 miles ago", you do not need to be doing 80 mph....at all. Let alone with the hubs locked in.
I have driven 70 in my 95 f150 with the hubs locked. Only because I completely forgot that I locked them in one spring when we got a late snowfall in early April. Roughly the beginning of June and 2500 miles later I was doing a front wheel bearing and stub shaft bearing. Was it 100 percent because the lockout was engaged? I do not know. But it COULD have been a factor. If you are dead set on driving that fast with the lockouts locked....have the front end inspected.
Old Mar 21, 2024 | 12:46 AM
AuroraGirl's Avatar
AuroraGirl
i think you are gonna find that wasting your breath on this guy gets tiring if you have not already. Hes clearly baiting this forum at this point. He blocked me for not answering things the way he liked and made a big public stink about it. And he is clearly lying somewhere about his knowledge or what he has done personally, like, he doesnt know what a heater hose is but hes also done a water pump and belt bypass on a 5.8 air pump.. like I dont think you can actually bne able to do the second thing without knowing what the first is lo..
Old Mar 21, 2024 | 08:21 PM
Nothing Special's Avatar
Nothing Special
Hard for me to answer that. I'm rarely on highways with a speed limit over 60. Even when I get out of the city Minnesota's speed limit is 70, and I typically drive the speed limit.
But going back to my rule of thumb, if I expect to need 4WD I'll lock the hubs until I don't. It would be an extremely unusual situation for me to be able to drive 70 - 80 mph any time that I expected to need 4WD. I wouldn't really hesitate to do it if the situation warranted it. I just can't really imagine I'd get in that situation, at least for long.
Old Mar 21, 2024 | 08:30 PM
Nothing Special
Yes and no. In the '90s or so Chevy Dodge and Jeep used a center axle disconnect. But those were kind of problematic, and I think most trucks now have gone to front axles that are always engaged.
And while some lighter trucks have likely gone to CV joints, heavier trucks still commonly use Cardan joints. But Cardan joints don't bind up (unless they're turned too far, and you can't do that in front axle joints, they're designed to handle to full lock). What they do is not move at a constant velocity (which is why they aren't CV joints). So you can get some vibration from the ring gear speeding up and slowing down twice per revolution when you're turning sharp. But you don't turn sharp at high speed, so it's nothing more than a slight annoyance.
Old Mar 25, 2024 | 02:01 PM
wannabuyaford
Hey I wanted to say thanks to everyone who responded. I drove again in the snow following the "manual" part of the manual and it was a night and day difference. It was actually really good in the snow. Thanks!
Old Mar 25, 2024 | 07:33 PM
Mudsport96's Avatar
Mudsport96
Ford used them in the 150s until 2020 and gm used them in suvs and half tons that I know of for sure till last year and possibly the 3/4 and 1 tons but not 100 percent sure on that.
Old Mar 30, 2024 | 01:02 PM
  #28
wannabuyaford
Oh also I drove at 70mph with the hubs locked and it seemed fine. "highway speeds" is vague but I guess it was accurate
Old Mar 30, 2024 | 01:04 PM
  #29
AuroraGirl's Avatar
AuroraGirl
Nothing vague at all about high way speed. What speed can you drive on the highway? usually between 55-80 mph in most statees, bar a few exceptions. Pretty damn clear to me lol
Old Mar 30, 2024 | 08:48 PM
  #30
'89F2urd's Avatar
'89F2urd
I've had some vehicles that have huge tires, lots of power, and factory speedo gear. I can wish, in hindsight, that the police viewed my "highway speed" to be vague. Granted, I have never gotten a ticket for speeding (not driving like an *** hole, weaving in and out of traffic helped my case), but I've been pulled over a dozen and a half times
msmith53
Jul 31, 2009 10:18 AM
IHdieselfan
Dec 15, 2007 09:23 PM
usmc-superduty
Apr 13, 2007 10:19 AM
luke245
13
Feb 15, 2007 09:40 AM
live2hunt
1983 - 2012 Ranger & B-Series
Feb 6, 2007 04:32 PM
