C5 Auto Transmission Modulator
Old Nov 24, 2003 | 10:42 PM
whalerron's Avatar
whalerron
My 1973 F100 has a C5 automatic tranny in it. The transmission modulator has 2 vacuum ports on it and my question is "Why are there 2 ports?" This is the first time I have ever seen a modulator with more than one vacuum port. And, Ford switched back and forth between single and dual port modulators in the mid 70s. Does the 2nd port do something to minimize emissions? Can I use a single port modulator in place of the dual port modulator?
- ron
Old Nov 25, 2003 | 06:06 PM
rclarke's Avatar
rclarke
The smaller port, farthest from the tranny, goes to spark vacumn. the larger port, nearest to the tranny, goes to manifold vacumn. Yes, you can use a single port modulator.
Unless you or someone changed it your tranny cannot be a C5, the C5 didn't come out till the 80's. If your tranny is stock it must be a C4. The modulator info is good for both trannys. You might also have a C6. Take a look here for help on tranny ID.
http://pages.prodigy.net/kennethl6/_wsn/page8.html
Old Nov 26, 2003 | 10:37 PM
whalerron's Avatar
whalerron
It is definitely a C4. A guy in a tranny shop told me that it was a C5 and he said the clue was the fill tube which attaches to the right side of the transmission pan. Obviously he didn't know what he was talking about.
Do you have any idea what the purpose of the 2 port modulator is? I noticed in the Ford manual that the second port is referred to as the "EGR port".
Old Nov 27, 2003 | 04:02 PM
rclarke's Avatar
rclarke
I never have had a complete understanding why some models had dual port modulators. It probably had something to do with the early emission systems. A single port modulator will operate the transmission just as well as the dual port.
benbuilder
Oct 6, 2019 05:08 PM
jaleus
Feb 15, 2017 09:33 PM
dtkkc
Sep 23, 2016 04:49 PM
RileyCarroll
Jul 29, 2016 04:01 PM
grandpas1974
Apr 8, 2016 11:34 AM
