OBS Bronco 6.0PSD
Old Mar 9, 2024 | 01:42 PM
FishOnOne's Avatar
FishOnOne
Old Mar 9, 2024 | 02:27 PM
'89F2urd's Avatar
'89F2urd
ugh, I shouldn't have watched this. A 6.0 swap has never crossed my mind.
Old Mar 9, 2024 | 03:05 PM
Baylinerchuck's Avatar
Baylinerchuck
Holy sheet that’s cool. I would love to know what that cost……I used to own an ‘86 Bronco, would have never thought I’d see one of those with a doesel in it. I guess anything’s possible if money were no object! 😂
Old Mar 9, 2024 | 10:09 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
David Lott of DI Performance did one of the first ones around 2008 or so. It was red and he did a really awesome job with it. These guys took it quite a few steps further
Old Mar 9, 2024 | 10:23 PM
'89F2urd's Avatar
'89F2urd
I put a 6bt into an oj bronco, prob 15 years ago now. The 6.0 would be a little more involved, but considering the obs came with a 7.3, some of the work would overlap to do a 6.0 swap. That said, 6.0 engines can be found for next to nothing.....a rebuild, studs, injectors can get pricey. It wouldn't be hard to throw 15-20k at a swap like this, unless a running donor was found cheap.
Old Mar 10, 2024 | 03:47 PM
wpg_250's Avatar
wpg_250
That's easily 100 grand right there, wow!
Watching this makes me want to go ahead with my 2016 cab on 2006 chassis project
Old Mar 10, 2024 | 05:09 PM
'89F2urd's Avatar
'89F2urd
FWIW, I've been around for the entirety of the diesel explosion in pickup trucks. I'd rather have mechanical, mechanical/computer hybrid (vp44), or heui than common rail. Common rail makes power the easiest, sure, but the injectors fail open and take out cylinders. The fact that common rail injectors means that you end up with a cylinder that is destroyed (and enough time has elapsed in the common rail scene to understand this to be true), means that these "primitive" injection systems are always on the table for swaps. I'd happily swap a 6.0 before a common rail, despite all the 6.0s potential problems, before I swapped a common rail..........if it were to build for myself. Of course, whatever the customer wants to spend their money on, is what they spend their money on.
Old Mar 10, 2024 | 06:02 PM
wpg_250's Avatar
wpg_250
Interesting, but not sure how this relates to my 2016 to 2006 cab swap reply?
Old Mar 10, 2024 | 06:13 PM
'89F2urd's Avatar
'89F2urd
cuz this thread is not that thread? Lol
Old Mar 10, 2024 | 09:03 PM
FishOnOne's Avatar
FishOnOne
Definitely not a cheap project, but it looks to be done with no expense spared. I would have preferred a little less lift.
Old Mar 11, 2024 | 02:44 PM
FiveOJester's Avatar
FiveOJester
Thats interesting he took a 06 chassis and swapped the Bronco body over. I guess that makes engine/trans mounting that much easier, just make the body fit. Way above my pay grade!
The 10-blade turbo sounds cool but I wouldn't want to drive that every day!
Old Mar 12, 2024 | 08:11 AM
Ford.Dude's Avatar
Ford.Dude
That is sick!!!! Beautiful ride. Thanks for sharing!
Old Mar 12, 2024 | 11:35 AM
FishOnOne's Avatar
FishOnOne
Checked out Kill Devil Diesel long blocks and prices range from $12k - $24k. Not too bad for a performance built 6.0PSD which I suspect this Bronco has one of the higher performing engines with that turbo whistle.
SDElwood
1966 - 1977 Early Broncos
Jul 4, 2015 12:43 PM
SDElwood
1978 - 1996 Big Bronco
Mar 31, 2015 07:15 PM
mdr617
Bronco II
20
Mar 17, 2011 11:01 AM
