AfterMarket Keyless entry
Old Nov 28, 2003 | 08:52 PM
hanklin's Avatar
hanklin
sounds simple enough, i guess. Thanks for helping me. This would be a nice gift from my wife to me.Hopefully I won`t have to call they`re tech support,you guys here at FTE have more ans than they obviosly would .thanks
Hanklin
Old Nov 30, 2003 | 12:14 AM
Code 5 Ford's Avatar
Code 5 Ford
Name?
How did you come up with the name Rogue River Rat?
Old Nov 30, 2003 | 10:51 AM
RogueRiverRat's Avatar
RogueRiverRat
River Rat was a nickname of mine back in my early 20's. Where I live now, the river is called the Rogue River..
Old Nov 30, 2003 | 01:37 PM
Code 5 Ford
Me too....We must live in the same area?
Old Nov 30, 2003 | 01:44 PM
RogueRiverRat
Well, if you can catch Salmon and Steelhead almost year round out of it, then we do..
Old Nov 30, 2003 | 09:15 PM
Code 5 Ford
I live in Rogue River.............
Old Nov 30, 2003 | 10:30 PM
iceman_1000000's Avatar
iceman_1000000
1st Gear
I don't know if you got your system figured out, but its a positive system. I just bought a crimestopper keyless entry with remote start and installed it over the weekend. I have a 99 powerstroke, and with mine you just have to hook up the two wires for lock and unlock.
Old Dec 1, 2003 | 03:53 AM
underp2's Avatar
underp2
any way to get a remote start on a manual tranny? most don't seem compatible.
Old Dec 1, 2003 | 08:00 AM
rmilchman's Avatar
rmilchman
The problem with a manual tranny is the risk of the truck being in gear when starting. Can not remember who made it, but I saw a switch that could be installed on the linkage to determine if it's in neutral.
Old Dec 1, 2003 | 09:33 PM
RogueRiverRat
Problem solved. Turned out to be reverse polarity. I had it hooked up right with the relays, just wasnt using a heavy enough fuse. Needed a 50 instead of a 30 amp fuse.. 75.00 dollars later, it works great.
Also, Desighntech does make a unit for a manual tranny.. They even have kits for carberated engines..
fordguy2236
1997 - 2003 F150
Jul 13, 2013 09:49 PM
sla3492
Mar 22, 2010 07:48 PM
ssjrsw
Jan 22, 2006 07:09 AM
aldridgec
1997 - 2003 F150
Jan 26, 2003 08:54 AM
