Help help help 2017 ford f250
Old Mar 5, 2024 | 10:15 PM
fosters0440's Avatar
fosters0440
3rd Gear
Replaced fuel system with a fuel contamination kit. Truck fired up and runs good. Went on a test drive truck does good if you gradually get in the throttle but if you smash the pedal down the truck jumps initially then rpm’s go up to 3,000 and the truck falls on it’s face. Watching the fuel rail pressure on a snap on Zeus and it’s 28,000 pounds (same as command) and never drops when at wot. Got back to the shop checked no leaks noticed a change in sound of injectors at idle looked at frp actual was 7,800 and command was 7,800 I know at idle it should be around 4,400 psi. Truck isn’t throwing any codes either
Old Mar 5, 2024 | 10:48 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
OEM kit???
Old Mar 6, 2024 | 09:00 AM
Foster0440's Avatar
Foster0440
3rd Gear
It is an OEM contamination kit, it does have the fuel saver on it also.
trevr6t6
Jan 27, 2015 02:33 PM
Lavern
Dec 26, 2012 06:53 PM
1999SuperDutyStroke
15
Jul 10, 2010 10:27 PM
sdbiddle
Jul 18, 2009 08:36 AM
79CEEJAY
Jan 24, 2004 11:33 PM
