stop leak
Old Mar 5, 2024 | 04:31 PM
JoePa2's Avatar
JoePa2
stop leak
I noticed some antifreeze coolant on my garage floor - not much but it seems to leak after I shut off the van and the pressure increases somewhat - after carefully looking for the leak I think I have a small leak at the botttom of the radiator - I was wondering if it was safe to use one of the stop leak products on the market - I don't want to clog up the system by using some kind of stop leak - I wonder what you guys think - anyone have successfully stopped a small leak - thank you
Old Mar 6, 2024 | 10:01 AM
manicmechanic007's Avatar
manicmechanic007
Your heater core will possibly suffer if you use stop leak
I'd rather see you replace the radiator
That said, Bars Leak works well and GM sells pellets over the counter to put in their vehicles
Jmac Radiator (now 1-800 Radiator) has bulletins discussing the GM pellets and the damage they cause
Old Mar 6, 2024 | 01:33 PM
blageurt's Avatar
blageurt
Manicmechanic is 100 % on this .... I only used it in an Emergency ...I think it was the Barrs ...worked but I had to flush the block and replace the Heater core because it was full of crap ( and OLD ) .... I would keep driving it and Monitor the leak to check actual amount it leaks ...make sure it is not the Hoses or a loose clamp....Then rebuild or replace the Rad...
Old Mar 7, 2024 | 04:42 AM
JWA's Avatar
JWA
An altenative to using that trash aka "Barr's Leak Stop" or its variants is drain the radiator, thoroughly clean and dry the observed leak area before properly applying a known good product externally like JB Weld for the time being. At some point the entire radiator will need replaced which can be done as the budget or time permits.
That crap "stop leak" is mostly problems waiting to happen, more commonly used as a stop gap way to pawn off a used vehicle on an unsuspecting buyer.
Old Mar 7, 2024 | 07:14 AM
tjc transport's Avatar
tjc transport
i ain't rite
i agree 1000% with all the above comments.
the ONLY stop leak i will use is blue Devil, and i only use that for a weeping head gasket.
and even that is a stop gap only until i can fix it properly.
Old Mar 7, 2024 | 09:31 AM
JoePa2's Avatar
JoePa2
Thanks Guys for your thoughts -
Old Mar 7, 2024 | 12:00 PM
annaleigh's Avatar
annaleigh
I bought my son a 94 regal and shortly after it started running a bit rough on a hot start up. coolant block test indicated exhaust gas in the coolant. Also the radiator had some brownish gunk in it. We did not think about it being stop leak at the time. We bulled the cylinder heads off and sent them to a shop where they were cleaned and tested and checked out as good. It turned out to be the plastic intake. But the heads were cleaned, the intake was new, and we installed new hoses and radiator. The only stop leak crud that was left was in the block and heater core. Last year my son took the radiator to a shop to have it flushed because it was starting to appear clogged in some areas.. I think the only way to remove that stuff would require basically rebuilding the engine. There would be no point in pulling the engine to have it vatted and not rebuilding it!
Shadhurst76
2015 - 2020 F150
Jan 27, 2024 11:25 AM
mibson
1983 - 2012 Ranger & B-Series
19
Nov 15, 2009 04:58 AM
B-52
6.4L Power Stroke Diesel
Sep 22, 2008 06:42 PM
dieself250
Nov 16, 2005 06:58 AM
