Radiator leak
Old Jan 26, 2024 | 01:44 PM
Shadhurst76's Avatar
Shadhurst76
1st Gear
Radiator leak
Hi I have a 2015 F-150 with a 3.5 l EcoBoost. The radiator has developed a small leak, and I was curious if there is any safe stop leak to use until I could replace the radiator? I bought a bottle of bars leak, but I'm hesitant to use it.
Old Jan 26, 2024 | 01:52 PM
Olds64's Avatar
Olds64
Bar's Stop Leak would be the one that I used. Have you verified it is the radiator that's leaking and not the cap or one of your hoses?
Old Jan 26, 2024 | 02:02 PM
JKBrad's Avatar
JKBrad
Where is the leak coming from?
Old Jan 27, 2024 | 09:55 AM
GlueGuy's Avatar
GlueGuy
+1
Before starting work on the radiator, be extra careful isolating the source. Hoses are cheap (and more likely to fail); radiators not so much. After 8 years, rubber components start to get brittle.
Old Jan 27, 2024 | 10:58 AM
fordman19762003's Avatar
fordman19762003
IMO I wouldn't use any type of stop leak product unless it was a life and death situation. I think there are just too many small passages on modern engines that could be plugged up with it. I'd rather fix the problem than throw a bandaid on it that could cause a problem down the road.
Old Jan 27, 2024 | 11:25 AM
JKBrad's Avatar
JKBrad
Agreed, stop leak products like Bars Leaks are only to get you by for a short period of time until you can get a proper repair done. Same idea as tires with products like Fix a Flat. If you rely on those products, they will ruin what you intended to fix with it.
rtcapo 61
Sep 8, 2019 01:43 PM
B-52
6.4L Power Stroke Diesel
Sep 22, 2008 06:42 PM
strokeman
Feb 22, 2007 10:49 PM
MemorexKid
1997 - 2003 F150
Feb 15, 2004 09:35 AM
todd_adams2001
Sep 30, 2002 11:41 PM
