6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
2nd Rad Leak??
Old Sep 18, 2008 | 03:26 PM
B-52's Avatar
B-52
2nd Rad Leak??
First leak about 20k had it fixed. Then I installed the Venturi T about 3 weeks ago. Now at 31K I am seeing another leak from the Radiator WTF??
Anybody else had 2 leaks with the "T" being installed? I thought the "T" was suppose to prevent it. My truck is a job #1!!
Old Sep 19, 2008 | 12:04 PM
Showtime's Avatar
Showtime
Yes my started to leak at the rad at 1200 miles they replaced it and then at 6000 it started to leak again. They told me at the time they did not know they had a rad problem so they just replaced it with the same one that had the same bad crimp joints. I am not sure if i have the t--- in my truck since they replaced the second rad i will check.
Old Sep 20, 2008 | 05:56 AM
chairman13's Avatar
chairman13
I had a radiator leak a week ago, since here in Poland I don't have to worry about warranty(ford dealer don't offer any of superdutys like all others in europe)I've bought a powder(I don't know how it is called in english)that stops coolant leaks, unless there is a big hole in the radiator. And guess what?? it stopped But I'm going to order a new radiator as soon as the leak comes back.
Old Sep 20, 2008 | 10:06 AM
DieselWhisperer's Avatar
DieselWhisperer
I believe we call that stuff "stop leak".
Old Sep 20, 2008 | 07:37 PM
cHiLi 11's Avatar
cHiLi 11
Mine was leaking at 15k, and they replaced mine with a new radiator.
Nick
Old Sep 22, 2008 | 05:11 PM
scsmith42's Avatar
scsmith42
I would estimate that your second radiator was damaged before the venturi kit was installed, and that's what caused the leak.
I've had two radiator replacements - one at around 7K miles and the second at 22K. The venturi t was installed along with the second radiator, no problems since other than a leaking upper radiator hose (now have 32K miles).
Old Sep 22, 2008 | 06:35 PM
B-52's Avatar
B-52
Yes they are putting a new Rad in it. Hopefully it all stays together this time!!
Old Sep 22, 2008 | 06:42 PM
Carl Lassiter's Avatar
Carl Lassiter
As scssmith said, leak was likely caused in the 10,000miles between installing your second radiator and having the Venturi kit fitted.
Glad your getting a new part and if I were a betting man I'd wager you'll have no further radiator issues.
SoCalAngler
18
Oct 31, 2014 04:08 PM
37 Ford guy
Jan 14, 2012 11:16 PM
wantaford
17
Aug 11, 2008 01:15 PM
ms1780
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Nov 4, 2006 09:50 PM
seebeew
Mar 5, 2003 12:49 PM
