Electrical issues
Old Mar 4, 2024 | 11:08 AM
bmick's Avatar
bmick
1st Gear
Electrical issues
Got a 1978 f150 with a 400. truck was running great and started right up but after i ran it the other day it wont come back on. It is getting absolutely no power anywhere. no lights, ignition, etc. I went ahead and bought a new starter solenoid cause thats what i figured it was but it wasnt. When i jump the solenoid it will turn over but no ignition so it doesnt run. fuse somewhere? i know these have in line fuses so could it be one of those? Battery has good ground and voltage and im just perplexed as to how it would happen so sudden like this
Old Mar 4, 2024 | 11:17 AM
440 sixpack's Avatar
440 sixpack
If it's not a battery connection then it's probably your fusible link. next question is what fried it?
Old Mar 4, 2024 | 01:14 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 yes I also bet the in line fusible link just down stream of the starter solenoid is soft and stretchy. X100 what caused it? Bad alternator, voltage regulator, random hot wire get grounded out?
xliwildkatlx
Jul 18, 2023 02:01 PM
red351
1978 - 1996 Big Bronco
Jun 18, 2012 05:57 PM
luckydamo
24
Feb 4, 2011 09:57 PM
$150_4x4
Apr 14, 2003 10:47 AM
85351ho
May 9, 2001 09:15 PM
