2016 skipping contribution balance code
Old Mar 3, 2024 | 08:14 AM
swingin6.7/6.4's Avatar
swingin6.7/6.4
2nd Gear
Hello all I recently ran into an issue with my 2016 6.7 shortly after replacing my intercooler, truck developed a skip and threw a p0272 (cylinder 4 contribution balance) and p02d3 ( cylinder 4 fuel injector A offset learning at max limit) I replaced the injector and programmed the new iqa in and no change. It will idle smooth sometimes and will drive fine above 1900 rpm. Other than that it’s still skipping and blowing whiteish blue smoke smells like raw fuel very strong. I did a relative compression test and came back all cylinders-0% other than cylinder 4 with -2%. Starting to think I’ve got a valve sticking I got the valve cover off yesterday and didn’t see anything out of the norm, going to tear into it more today what else do you guys think? Truck is tuned and egr dpf removed only mod is titan 9 blade and swag performance intercooler.
Old Mar 3, 2024 | 04:29 PM
senix's Avatar
senix
check with the tuner folks.
Still get the same codes?
Old Mar 4, 2024 | 10:24 AM
speakerfritz's Avatar
speakerfritz
See if there is any side play in the rockers esp the long ones.
foul1
Aug 27, 2022 04:22 PM
David Fehir
Sep 18, 2017 07:55 PM
Hunterisdavid
Jan 12, 2013 01:09 PM
smitty403
Aug 11, 2012 11:51 AM
MAKO314
Apr 13, 2007 09:18 PM
