Boost Measurement Variations
Old Mar 4, 2024 | 07:05 AM
  #31
OldMechanic57's Avatar
OldMechanic57
Updating. Set the scaling to 0-50 and it seems to be very close now. MAP boost stops at 21 psi and the EAS goes on up to around 33 psi. Thanks for all of the input.
Old Mar 4, 2024 | 07:32 AM
  #32
Tpayne621's Avatar
Tpayne621
I think you mean you set it to 0-100. But either way good deal. Glad you got it figured out.
Old Mar 4, 2024 | 10:27 AM
  #33
OldMechanic57
Fuel is set to 0-100. Boost is set to 0-50. Both sensors are available for “scaling” in the EAS settings for each sensor. It all seems to be correct now. Boost is within .5 psi throughout the range of both the EAS sensor and the boost pressure reading generated by the MAP sensor. I honestly thought that I had initially set the scaling to 0-50 before I even started this post. Anyway, it was a good brain teaser and some good conversation. Thanks guys.
Old Mar 4, 2024 | 10:56 AM
  #34
RacinJasonWV's Avatar
RacinJasonWV
I think we may be talking about different “setting” points.
I suspect the gauge display has a settings range just for the display.
But there may be a sensor calibration type of range setting as well. That’s to let the system know what voltage corresponds to what psi.
I’m guessing somewhere along the way you’ve corrected the sensor setting from 0-50 to 0-100 which made it read right. But left the display itself at 0-50 because we don’t need the to see the full scale since it will never be used.
Does that sound about right?
Old Mar 4, 2024 | 11:02 AM
  #35
Tpayne621's Avatar
Tpayne621
@RacinJasonWV correct it has options for both.
Old Mar 5, 2024 | 12:33 PM
  #36
Horven's Avatar
Horven
7th Gear
I just installed the Edge 0-100 psig sensor to measure boost with my CTS3. I had to use to choose custom setting in the drop down menu and set .05v = 0 and 4.5v = 100 It was measuring 1 boost at idle until I drove it around a bit and it works correctly now.
Brooklynh87
21
Dec 7, 2021 09:43 AM
jk651
Jul 30, 2021 07:47 AM
Capt.Schenk
23
Jan 19, 2017 08:19 AM
20powerstroke02
Nov 17, 2014 07:21 AM
Diesel and Steam
Sep 17, 2010 12:28 PM
