1999 E-350 speedometer malfunction
Old Feb 28, 2024 | 02:27 PM
Bigw's Avatar
Bigw
4wd Low
My 1999 E-350 van suddenly began having erroneous speed readings. The speedo goes from zero to 40 MPH as soon as van begins to roll…..the it does not increase to true speed beyond 40 MPH. When van slows to zero the speedo gradually goes back down to zero MPH. No Check Engine light, trans shifts well, cruise seems to work fine, …..I just replaced the battery and before replacing battery did a jump start. Speedo worked fine for over 100 miles before malfunction. Please give me some ideas about how to troubleshoot. Thanks!
Old Feb 28, 2024 | 07:55 PM
DBGrif91's Avatar
DBGrif91
It’s not likely to matter, but what engine? There could be minor differences in the connecting circuits at the IPC connectors.
The speedometer is logic controlled within the IPC. The VSS is directly fed to the IPC and PCM/TCM.
If you’re not experiencing any shift or driveability issues, it’s likely the cluster is at fault. A scan tool or app that can check live data within the cluster would be the most useful/effective way to determine if it’s a cluster or signal problem.
Old Mar 6, 2024 | 01:54 PM
blageurt's Avatar
blageurt
I had similar Issues with my 99 Diesel and all I did was remove / replace all the relevant Fuses and Relays and it stopped ....If you have the manual it tells you what is what ...Otherwise you need the Electrical Service Manual ....some times it is just a bad contact or wire rub -out ...buy a can of Electric Contact Cleaner and some Dieelectric Grease and go to town ...Also Clean and Tighten your Battery Terminals too ....Good Luck ....
Old Mar 6, 2024 | 10:04 PM
Don Ridley's Avatar
Don Ridley
Here is the wiring diagram.
https://charm.li/Ford%20Truck/1999/E...ent%20Cluster/
Fasz Kalap
Sep 11, 2023 07:08 PM
hav24wheel
Mar 9, 2023 12:51 PM
buck_
Nov 6, 2021 10:15 PM
Steve Aerostar
Aerostar
Sep 8, 2014 06:31 AM
munrow
Mar 9, 2005 09:35 AM
