Speedometer Issues
Old Mar 8, 2023 | 04:30 PM
hav24wheel's Avatar
hav24wheel
Speedometer Issues
99 E350, Speedometer climbs from 0 to 40mph close to normal, (as vehicle continues to speed up) than kinda hangs there for a wile, and than starts to drop down to 30 or so, than drops to 0, as vehicle reaches 70 mph. Odometer reads as it should, and the cruise control works as it should even when the speedo shows 0. Bad stepper motor??
Old Mar 9, 2023 | 05:02 AM
JWA's Avatar
JWA
^^^ That would be my guess especially if the Odo seems to be working meaning its motor is receiving the proper signal.
Old Mar 9, 2023 | 05:45 AM
manicmechanic007's Avatar
manicmechanic007
Check the VSS pid
Replace the VSS
With a intermittent faulty VSS, the odometer will still tick off miles, while the speedometer goes nuts
Old Mar 9, 2023 | 08:37 AM
Don Ridley's Avatar
Don Ridley
Junkyard instrument clusters are about $50. If mileage is close, just swap units. Otherwise use the junkyard unit for parts/repair.
Old Mar 9, 2023 | 12:51 PM
hav24wheel's Avatar
hav24wheel
I did a 4x4 swap on this thing, so the speedo is driven off a different sensor than the stock trans now. I added a Dakota Digital converter to get the speedo to read spot on. Never had a problem until the Battery went dead one day. But I checked out the Dakota unit, and that isn’t faulty. So I was thinkin the stepping motor.
if the VSS was bad, wouldn’t the CC act up and not hold a steady speed?
If I swap clusters I am looking at getting one with a tach. Have to change pin outs but supposedly can use a Superduty one in the Vans.
4xfourdoorFloyd
Jan 15, 2023 11:21 AM
rvpuller
May 29, 2019 10:16 AM
ibewshooter
2015 - 2020 F150
Sep 27, 2017 05:32 AM
mustang_gt_350
May 29, 2007 10:29 PM
bobbav
1983 - 2012 Ranger & B-Series
May 2, 2005 05:09 PM
