Aerostar Ford Aerostar
Speedometer error
Old Aug 29, 2014 | 12:20 PM
Steve Aerostar's Avatar
Steve Aerostar
Speedometer error
Gave my "96 Aero" a road test from home in Ohio to North Carolina last week.
Drove approximately 1400 hundred miles.
I was using my Garmin GPS and noticed that the incdicated speed on the speedometer was 5 mph less than that on the dashboard dial. Also the odmoter was gaing approximately .1 (one tenth) per mile. If this has been the case since the van was new it has about 9K less than what was on it when I purchased it a month ago.
Any ideas on why the speedometer is not givig the correct speed?
The original tire size was 215/75 but the tires on the van now are 215/70. I doubt if this minor difference in diameter would cause a 5 mph error.
Can the speedometer error be corrected?
Old Aug 29, 2014 | 03:44 PM
Jose A.'s Avatar
Jose A.
I also have noticed the same error using my Garmin Nuvi gps. It's the Garmin, not your speedo. Mine gives me a 2.5 mph error using the same size tires.
Trust the speedo, not the Garmin.
Old Sep 7, 2014 | 10:18 AM
KhanTyranitar's Avatar
KhanTyranitar
I disagree with you completely Jose. The Garmin is accurate, in fact GPS speedometer technology is the most accurate, with radar and laser based systems coming in second.
All Aerostars are off because the speedometer is actually calibrated for a larger tire than Aerostars ever came with stock.
How do I know its the speedometer thats the issue? Well, Garmin is not the only one that indicates you are going slower than the speedometer indicates. All other GPS units do it too (Tomtom, Maggellan, Apple Maps, Google Maps, Motion X, etc.) Ground based systems like the speed warning signs, cops, etc. confirm the same thing.
Old Sep 7, 2014 | 01:54 PM
Steve Aerostar
Agree with Khan
I took my Garmin out in my other Aerostar, the 96 with (4)EWD, my Chevy Impala and my Chevy Malibu. The Garmin was spot on accurate with the speedometers in these three vehicles. The Garmin is dead accurate, the speedo in the my 2WD Aero is off.
I also noticed since posting the vehicle was originally supplied with 215/75 tires but now has the lower and wider profile 215/70 size. Wonder what this difference makes?
Regards
Steve
Old Sep 7, 2014 | 07:51 PM
xlt4wd90's Avatar
xlt4wd90
The nominal difference is about 3.3%, but the actual difference could be more or less. It's very unlikely for two tire makes/models with the same size designation to be actually the same size. For one thing, the width designation is the nominal width of the tire at its widest point.
Old Sep 8, 2014 | 06:31 AM
Jose A.'s Avatar
Jose A.
I did a test yesterday:
two vehicles going 70 mph each, both reading 70 mph at the speedo, both with same size tires, both "stabilized" at 70mph on the road, both with different GPS, (one a Cellular Phone GPS, one with my Garmin), both GPS with same destination address, both of us connected via cellular phone; Upon reaching and maintaining 70mph speedo speed for one minute, then reading the GPS speed, one GPS showed 69 mph, the other showed 71 in RED.
Neither GPS showed 70mph.
so which was the accurate reading if two vehicles are showing 70 mph at the speedo?
does it really matter?
metru
Nov 8, 2017 09:26 PM
ibewshooter
2015 - 2020 F150
Sep 27, 2017 05:32 AM
Ltngdrvr
6.7L Power Stroke Diesel
34
Apr 25, 2014 12:03 AM
shia1
1978 - 1996 Big Bronco
May 26, 2009 04:32 AM
tomucen
Aerostar
Feb 4, 2001 07:20 PM
