Sponsored by: Real Truck
Superduty help please
Old Feb 25, 2024 | 07:54 PM
K5BEAST's Avatar
K5BEAST
1999 f250 superduty 5.4L 4x4 manual tranny.
So yesterday in town I come out of store, jump in truck, turn key and nothing. A few tries later it finally cranked over and started. Next stop I come out and nothing again. No crank. Ended up crossing the solenoid on the fender to get it started.
Spent all day on it today and got nowhere. Everything else works as it should. I have a parts truck so I swapped various things. Ignition switch checked out, swapped anyways. No change. Clutch safety switch checks out, swapped anyways. No change. Checked all fuse in both boxes. All good. Battery is a good optima. Hooked up battery charger also. No change.
I can manually put power to the small signal terminal on the solenoid on the fender and it will crank and start so that tells me downstream is good. Just put a new starter in a few weeks ago also. I have no voltage at signal wire at solenoid when trying to start. Odd thing I did notice is I'm only getting 5.2v at clutch safety switch. I even bypassed/ jumpered the switch just to see. No change.
I'm at a loss as where or what to do now. Would a bad GEM affect this at all? It's about ready to get a push button start wired in.....lol.
Old Feb 26, 2024 | 09:10 AM
madsonp's Avatar
madsonp
I think the first thing I’d suggest is cleaning your battery terminals real good.
Old Feb 26, 2024 | 10:55 AM
redford's Avatar
redford
FTE Leadership Emeritus
Have you checked the brake switch?
Old Feb 26, 2024 | 08:56 PM
99f350sd's Avatar
99f350sd
Gem shouldn't have anything to do with starting on a 99. You are going to have to check wires and connectors. Do wiggle test first...Disconnect wire from starter and put a test light from it to ground.
Have someone hold key to start and wiggle the wires. Watch for light. Make sure final connector isn't bad...the one that connects to the solenoid..
Stop replacing parts...Diagnose. You could be making more problems.
Old Feb 27, 2024 | 12:08 AM
K5BEAST's Avatar
K5BEAST
I've only swapped parts. Cost me nothing. I gave up and ran a new wire from the ignition switch to the starter solenoid. Works great now.
Old Feb 27, 2024 | 08:29 AM
Mac Daddy's Avatar
Mac Daddy
Neutral safety switch.
-Mac
Old Feb 27, 2024 | 07:10 PM
K5BEAST's Avatar
K5BEAST
-Mac
Is a manual tranny
Old Feb 27, 2024 | 07:48 PM
Mac Daddy's Avatar
Mac Daddy
Then clutch switch.
-Mac
Old Feb 27, 2024 | 11:06 PM
K5BEAST's Avatar
K5BEAST
Yellow top optima. No corrosion to be had.
Old Feb 27, 2024 | 11:09 PM
K5BEAST's Avatar
K5BEAST
Quote:
Then clutch switch.
-Mac
Quote
jumpered it at first then bypassed it completely. No change. Only thing that has made it work was running a new wire from ignition switch to starter solenoid. Afterwards I ran it through the clutch switch for safety. Still no clue on the original wiring issue. My assumption is a broken or half broken wire in the harness somewhere. All appears well, no damage to the harness to be seen.
1996F250HD
Jun 3, 2020 12:25 AM
rowdyredneck
Jul 1, 2017 09:48 AM
crispyton
16
Sep 19, 2015 10:08 PM
theredneckrussian
Dec 23, 2013 03:33 PM
77short4x4
Apr 15, 2013 11:42 AM
