haunted truck?
Old Apr 12, 2013 | 06:46 PM
77short4x4's Avatar
77short4x4
haunted truck?
okay guys i got a new one, first off with out the truck being on or even having a key in it my truck is trying to turn itself over, the only way i got it to stop was disconnect the battery. any ideas on what could be causing this? my dad who has had handfuls of of 73-79 fords and this is the first time he's ever seen anything like this.
Old Apr 12, 2013 | 07:14 PM
jim collins's Avatar
jim collins
___Starter solenoid bad maybe ? Contact parts in it stuck together from a short maybe __Sorry best i can do.
Old Apr 12, 2013 | 07:50 PM
Filthy Beast's Avatar
Filthy Beast
When you go to check it again, if it does the same thing, try pulling the 'S' wire off the solenoid while she's trying to turn over. If it stops, the problem would be in the wiring from the switch to the solenoid - a shorted/fused always on type deal. Or, the ignition switch itself. Or the neutral/clutch safety switch.
If it still does it with the S wire disconnected, it's what Jim said - a shorted out solenoid. Try smacking it (the solenoid) with a small beater - maybe it'll loosen up the shorted contacts.
Old Apr 12, 2013 | 08:22 PM
apbtpetey's Avatar
apbtpetey
My mustang did the same thing and it was the ignition switch. Changed it out and problem solved. I would check the starter solenoid first though.
Old Apr 12, 2013 | 09:19 PM
GM4WALLS's Avatar
GM4WALLS
Sounds like the original owner is back from the grave trying to repo his ride! Lol. I had a solenoid that stuck on my old 4x4 and it would continuously crank until the battery died even with the key off. I replaced it and never had the issue again.
Old Apr 12, 2013 | 11:14 PM
9d4's Avatar
9d4
at least yours tries to start. Mines haunted with an electrical problem from hell that no one can figure out
Old Apr 13, 2013 | 12:52 AM
ZP3's Avatar
ZP3
Mine did that,then I changed both the Ign. switch and solenoid. It fixed the prob,but then smoke started willowing out from the steering column and the truck died and will only turn over now.
Old Apr 13, 2013 | 10:01 AM
fmc400's Avatar
fmc400
MSEE
It's either the starter solenoid or the ignition switch. The method described by Filthy Beast will narrow down which one.
Old Apr 13, 2013 | 01:32 PM
77short4x4's Avatar
77short4x4
alright thanks everyone, i don't think it should be the ignition i literly just changed that out a couple days ago. ill see if the solenoid will do it
Old Apr 13, 2013 | 01:37 PM
fmc400's Avatar
fmc400
MSEE
Just because the ignition switch is new doesn't mean it's not the problem. We're are not telling you to replace your solenoid (yet). We're explaining a simple test to perform next time the problem occurs to isolate the issue. If it happens to be the solenoid, then great, but hold on to your $25 for now until you have more information.
Old Apr 15, 2013 | 10:12 AM
Feardeere7's Avatar
Feardeere7
I only payed like 8 bucks for mine!
Old Apr 15, 2013 | 11:42 AM
Dave145's Avatar
Dave145
It's probably the solenoid. My truck did that this morning after I kept trying to start it on a dead battery. The battery had just enough juice to make the solenoid move and close the circuit and get stuck. I walked over the the solenoid and tapped the top of it with a hammer. Then the truck acted as normal
Scorcher21
Aug 6, 2016 12:02 PM
Jrtouchton
Jun 8, 2016 08:24 PM
ford4her
May 16, 2015 05:32 PM
muddybrazos
Jun 3, 2011 09:59 PM
1959_f100
Dec 17, 2008 01:04 AM
