Center console swap?
Old Feb 21, 2024 | 04:16 PM
BeringF250's Avatar
BeringF250
I got a 2021 f250 with front jump seat im looking to swap to a center console. Have any of you done this swap before? If so which year consoles worked and are there any other wiring harness needed etc?
I’ve watched some YouTube videos on a few swaps. It’s doable but the hang up seems to be, to power the cig lighter and two USB’s after swapping to the center console.
Old Feb 21, 2024 | 05:02 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Here's the big thread on it:
https://www.ford-trucks.com/forums/1...sole-swap.html
I did it to my 2018. Front USB was easy...I just re-routed the one that was up there to the console. I didn't worry about anything in the rear, as I don't have passengers back there.
Old Aug 20, 2024 | 09:29 PM
Splxt's Avatar
Splxt
3rd Gear
hey man. Did you have a single USB? Or did you have a double already? If you had a single, can it be swapped to a double? Maybe a type an and a type c? I’ll be uograding my head u it in the future.
Old Aug 20, 2024 | 10:16 PM
BPTS's Avatar
BPTS
I did my ‘19 & my ‘20 with the same console (pulled the console when I traded in the ‘19 for the ‘20).
For me the biggest PITA was getting the correct dash trim pieces- during the COVID cluster you couldn’t find squat.
You need the console bracket that bolts to the floor and the wiring harness.
Find a truck similar to yours and use the last 8 of the VIN to order the harness for it.
I got to where I could swap it out in about 30 minutes.
Old Aug 20, 2024 | 10:22 PM
Splxt's Avatar
Splxt
3rd Gear
hey man. I can order an entire dash all
parts minus harness. I have a 19 xl. So I am not even sure what harness I would need…. Maybe ford can help me. Did you have any wiring issues when getting everything hooked up? I have following: 1usb, 1 12v. Both below climate control. 2 12v where some have the power plug. And one in the back of the jump seat. I’ve heard many say they can’t get barely any of it working.
does this sound familiar? HC3Z-19A387-B
or maybe this? This is a fall harness.
https://www.ebay.com/itm/395375377916?_nkw=ford+hc+3+z+19+a+387+b&itmmeta=0 1J5SFH9CCDJNW84WSW1Q6GSHA&hash=item5c0e357dfc:g:Z1 gAAOSwUNdmMaXD&itmprp=enc%3AAQAJAAAA8HoV3kP08IDx%2 BKZ9MfhVJKlJMIe9xuvpwjQz8osmfYaWIOlEcNXxrTq6ZuoUft VY1l3FWRJW%2BQpzxmcEkXjgPmkdHMNUg%2F6elvEuzJ5ulObQ 3FZnawrFboIbZspdfs%2B4aAAcEwqddH29pmyXxY1FcS3bdWFL Mln%2BnHfuaQhjhKCtlq5RrKcECEKbMehGZ85umEB5m7%2BCoK bohSvMI2oGYapzWPNjvUpH02cU8ZCc%2B%2BFTofmK8Pq4oNFp S4EB304jG8e4%2Bw7petyBekDKfez%2BN6J0a4QOXJxg8qG3s2 cU%2F7IHi9ESIJKGArLyXjdb3kD1xA%3D%3D%7Ctkp%3ABFBMo JbFr65k
Old Aug 21, 2024 | 04:51 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Just the single USB in that truck.
Francisco_6.7
Jul 9, 2023 09:56 AM
mikem2376
Dec 7, 2021 01:23 PM
gjack13
1997 - 2003 F150
Jan 8, 2019 07:31 PM
mtmatzf150xlt
6.4L Power Stroke Diesel
Jul 1, 2013 09:57 PM
