Hole in the roof
Old Feb 21, 2024 | 03:28 PM
Nick05's Avatar
Nick05
Hole in the roof
Been thinking I have a hole from rust in my 1997 crew cab and wanting to fix it during the summer or sometime sooner. Pervious owners had a anntena on the roof about between the front and rear seats. Thinking of either just weilding sheet metal or getting a rear sliding window from a same year truck and using it as a sun roof. Wanting the pro and cons and if the window will be able to be sealed when shut.
thanks for any insights
Old Feb 21, 2024 | 03:35 PM
Jim_K's Avatar
Jim_K
I've never seen a sliding rear window that was water-tight.
Of course there could be one out there, but I've never seen one!
Old Feb 21, 2024 | 04:58 PM
Nick05's Avatar
Nick05
I was thinking of using some type of sealent around the edges. Only issue I think of is the area it close and open thinking maybe like some plastic that would over it when it rains? And water drainage since probably won't be perfectly fleshed with the rest of the roof.
Old Feb 21, 2024 | 06:50 PM
Jim_K's Avatar
Jim_K
That's one of the places where they leak, where the two pieces of glass come together.
The other is worse, and that's the channel that the glass panes slide in. Can't think of any way to seal that one up.
If you really think you need to cut a hole in the top of the cab, maybe look around for a used sunroof.
Old Feb 21, 2024 | 08:04 PM
rla2005's Avatar
rla2005
Bad idea to reuse a sliding rear window as a sun roof. Going from bad to worse.
Old Feb 21, 2024 | 09:40 PM
wwhite's Avatar
wwhite
That’s your best bet, fix the hole, and never cut a hole in a perfectly good roof.
in 2010 ford truck they cut a hole in a brand new roof for the satellite antenna, guess what…it leaked from the factory.
if you want leaks, cut a hole.
Old Feb 21, 2024 | 10:42 PM
Nick05's Avatar
Nick05
Yeah good point have asscess to one that's close to free thought I get some pro and cons of a sliding one. Think one that's dosent open might be better?
Yeah that actually what caused the rust hole in the first place some kind of antenna found it funny how exact some problem you've mention is what caused it.
Old Feb 21, 2024 | 10:49 PM
wwhite's Avatar
wwhite
It’s a roof to keep the elements out, cut a hole it will leak… eventually.
any hole 2-4 years will leak, maintenance must be done if you proceed.
boats, every year.
Old Feb 22, 2024 | 06:54 AM
rla2005's Avatar
rla2005
No. It's still a bad idea.
Old Feb 22, 2024 | 01:23 PM
irhunter's Avatar
irhunter
Thinking of just weilding sheet metal
Another option.
Cut away rust (making the hole larger). De-bur and paint hole and over-lapping sheet metal patch. Glue the patch down with 3M 5200. It takes a week to cure, but it will last close to forever.
Roy
Old Feb 22, 2024 | 01:37 PM
Nick05's Avatar
Nick05
Originally Posted by irhunter
Another option.
Roy
can I still drive the truck while it cures?
Old Feb 22, 2024 | 02:03 PM
irhunter's Avatar
irhunter
Maybe. Cover it in plastic, and after 24 hours start to drive it????
There is also a fast-cure version.
Amazon Amazon
These are designed for below-the-waterline marine applications. Totally bomb-proof stuff.
Paint it after full cure.
Roy
Old Feb 22, 2024 | 03:15 PM
Nick05's Avatar
Nick05
Old Feb 22, 2024 | 04:39 PM
irhunter's Avatar
irhunter
Copy that.
But, remember: Rust Never Rests.
Old Feb 23, 2024 | 12:18 AM
TobyB's Avatar
TobyB
There were some truly miserable aftermarket 'moon roofs' in the '70's-
it took me until 2010 to be able to get into a car with a proper sunroof.
t
Vinford
Nov 14, 2021 08:37 AM
DanPannell
Ontario Chapter
Mar 1, 2017 05:11 AM
ericford1984
Jan 21, 2012 04:07 PM
caperail
Paint & Bodywork
Nov 8, 2004 09:36 PM
chaindrive
2004 - 2008 F150
Feb 3, 2004 01:10 PM
