1994 FLareside problems
Old Feb 21, 2024 | 01:27 PM
POSflareside's Avatar
POSflareside
4th Gear
i've got a 1994 flareside with the 5.0 and 4x4 e40d transmission and I've got a few problems. the transmission problem happend way before the engine problem
number 1, random hard shifting, ill be driving for 10-20 mins and then suddenly it'll hard shift, it shifts hard in every gear, pulling over and turning the truck off and on and it'll stop doing it for awhile and it may or may not do it again before the hard shift ill shift to 2nd around 20 mph when it hard shifts i shift to second in 10 mph or lower. no LED's anywhere on the truck and 3rd brake light works. no check engine light
number 2 engine surge. it surges on idle while driving normally and even worse uphill it feels like I've got a lose of power to i have to floor it to just get up a hill. starts up with no issues. also doesn't throw codes or check engine light
Old Feb 21, 2024 | 01:47 PM
Prototypemech's Avatar
Prototypemech
Check for codes.
check your tps sensor for open spots in the travel. It should have a nice smooth sweep like this.
Old Feb 21, 2024 | 01:54 PM
POSflareside
4th Gear
what is that, that your using to check the tps
Old Feb 21, 2024 | 03:02 PM
Prototypemech
That's an oscilloscope. You can buy a cheep one off eBay for $40. You can also use a multimeter to watch the value increase smoothly.
Old Feb 21, 2024 | 03:12 PM
Prototypemech
sncblue03
Jun 8, 2009 04:28 PM
perryau1996
Apr 4, 2008 07:52 AM
Copedawg
Dec 8, 2006 03:41 PM
cbledge
1978 - 1996 Big Bronco
May 6, 2004 09:22 PM
digr
Apr 24, 2004 03:00 PM
