eod transmission shifting problems
Old Apr 24, 2004 | 11:30 AM
digr's Avatar
digr
4wd Low
I just bought a 1996 f-150 4x4 351 automatic and I am having a shifting problem. The truck shifts fine most of the time but once in awhile after I shut it off it will not shift out of low and will not hold back. The only way I can get it to shift is to shut it off and restart and most of the time it will shift again. Another problem I am having and don't know if it is related is it misses all the time when the engine is at a low rpm and pulling hard. It runs fine when I use passing gear. Any ideas?..........Digr
Old Apr 24, 2004 | 03:00 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Stop driving the truck until you are sure the transmission is not in self-destruct mode. These things can get very expensive. Troubleshooting guides are available in professional repair manuals, check the library, and at transmission parts houses.
Badboy4wd
Dec 21, 2014 09:00 PM
Lazarus88
Jun 16, 2014 08:57 AM
Duncansm
Jun 6, 2014 06:00 PM
tnut
1983 - 2012 Ranger & B-Series
Feb 18, 2008 05:53 PM
dieseldude067
21
Nov 21, 2007 06:50 PM
