plow prep pkg affecting ride quality
Old Feb 17, 2024 | 05:13 PM
  #31
bigwin56f100's Avatar
bigwin56f100
My 22 I did the camper certification and it had the warning that the ride would be stiff. It got me the extra rear leaf overload and rear sway bar I have a 7.3 gas. I did not spec plow but I think 23 the plow/camper certification are combined? My truck rides very firm.
Old Mar 26, 2024 | 04:28 PM
  #32
deraeler's Avatar
deraeler
Trailering
O/P comments/responses
I will likely use a camper - no one at Ford dealerships seems to be able to answer this. In orderof priority for me:
1. Towing
2. Trucek/bed Camper
3. Front hitch for bike racks
4. Plowing
I'm very tempted to get the 250A alternator and dual batteries on a new F250 Lariat SC.
a. I ike the idea o fthe rear 2KW power accessory, although I admit to knowing of few uses for it at present. Among them - running a few select power tools in remote areas, charging up a camper as if on shore power - albeit briefly, and maybe powering a boat trailer winch so I don't need a dedicated batery on the trailer for it. I would presume the engine has to be running in roder for this to even functino - correct? OR does it run until the battery gets to a lew level and then shut off / require an engine start?
b. I may install a serious sound system at some point, music lover here.
c. putting on a plow, but it sounds as if plows will run ok on a singel alternator and battery, with a little light dimming...
thoughts?
Old Mar 26, 2024 | 04:58 PM
  #33
rna352's Avatar
rna352
thoughts?
It worked this way for years so it's probably not a problem. Be advised that even with dual batteries & alternators, the current draw from raising my plow occasionally causes the radio to cut off and back on again. So there's a possibility you might see this more frequently with a single battery setup. The electrical systems on these newer trucks are sensitive.
Old Mar 26, 2024 | 06:14 PM
  #34
Quad Racer's Avatar
Quad Racer
My 08 had the plow prep and I liked that it made the truck mostly level. And the little rougher ride didn’t bother me.
Old Mar 26, 2024 | 10:35 PM
  #35
bent-1's Avatar
bent-1
I have a swb super cab f350 with plow prep & camper pkg. work tk is lwb, crew cab f250, both 4x4. I can’t detect a ride difference, but plow & camper sits a bit higher.
Old Mar 27, 2024 | 09:12 AM
  #36
morehouse7's Avatar
morehouse7
I have the plow prep and single battery, It usually only does it to me when pushing heavy wet snow uphill and trying to raise my plow. I have heard some people added a capacitor and eliminated it. I bought one and planned to add it last spring but I decided to start tearing my house down to the studs and redoing it from the outside. Then it rained every day so I only got half way around. I will try to wire it before next winter and see if that fixes the issue.
Old Mar 27, 2024 | 11:25 AM
  #37
AmateurWheels's Avatar
AmateurWheels
Plow prep on diesels also includes the rapid cab supplement heater.
TheFarm1019
Jul 13, 2021 08:49 AM
AtleeH
Jul 13, 2021 07:35 AM
bowler1
Jan 24, 2018 10:55 AM
snelldawg
Oct 26, 2016 05:39 AM
grampscamper
Aug 14, 2012 01:20 PM
