TPMS Signal Loss
Old Feb 13, 2024 | 06:19 AM
erniek70's Avatar
erniek70
TPMS Signal Loss
2017 F350, 6.2L Lariat, SC. I have been getting sporadic, front left, loss of signal from the TPMS. I have recently replaced all 4 sensors, and I am still experiencing the same issue. Could it be the power supply to my dash cam causing interference? I had read that could be a root cause. Could it be the receiver is slowly failing? I believe this is the part number: GD9Z15607J (ford parts link below). Where is it located? Near the fuse panel in the passenger foot well? Any other possible signs the receiver is slowly failing? Once in a while, I cannot lock the doors, with the thumb sensor....I believe it might be through the same module. Any thoughts?
Transceiver. Keyless Entry Receiver. | FordUS
Old Feb 13, 2024 | 07:32 AM
OX2's Avatar
OX2
You might be at the point you need some kind of scan tool. For just the TPMS, I have this one.
it does plug into OBDII port for system diagnostics
Amazon Amazon
Can get em lightly used for under $200 many times.
https://www.ebay.com/itm/186287413934?epid=2298265875&itmmeta=01HPHAJH1YW9Q 33VVE08P14WQS&hash=item2b5f985aae:g:trkAAOSwFyRlwV 6K&itmprp=enc%3AAQAIAAAA4CiKd1f2hR4LyZRoYybCj%2FhT O2jAnXpbndmNw11K%2BFJYwLM95f75H9lnLarg50KfOyaOcY1Y 4W%2Bcjra46cID3UprZ3vzh98MYuPW4pSMTyPaX16vZEGy78r8 4ykBm%2BnMdj05URPrUhJLkDFu7d28qWZnPur4PRJRssnHPPj5 ju6u%2Fnh8HBVg8hxF%2B1e1u%2FcpOoo%2FQRGLs8z7LgIZUZ LquQcjJsn2KdrDNrTNTFtXFRAWSbIoEkiRFFWr1%2FNMZYOYU% 2B2CZk3cVjrpFp3OBbMlvCcyf54Md1tS%2Fnx6FYJfHBfo%7Ct kp%3ABk9SR5KRyqq0Yw
FORSCAN will read codes on all the modules also, but I have not used it for TPMS diagnostics, so maybe others can chime in.
Old Feb 18, 2024 | 02:35 PM
adamsfbay's Avatar
adamsfbay
I replaced my TPMS sensors with compatible aftermarket. Was assured they’d be AOK. Constantly dropped signal. Went to OEM, problems gone. Only use OEM.
jomoflymo
Oct 7, 2014 06:28 PM
onriver365
Jan 6, 2013 08:49 PM
irlfan360
Jan 18, 2011 07:23 AM
rmalottwtes30
Jul 23, 2009 06:08 PM
Agemenon
Dec 18, 2007 09:58 AM
