Turn Signals Quit
Old Jul 20, 2009 | 06:53 PM
rmalottwtes30's Avatar
rmalottwtes30
Turn Signals Quit
My turn signals quit on my way to work today. I turn them either direction and nothing. Tried with my lights on and off. My four ways still work. I am thinking my turn signal cam crapped out, because you always had to hold it in position to keep the turn signal on. Is there anyway to test the turn signal cam? I took it completely out and seen if I could see anything wrong but dont see anything. Hope to get some opinions and help because my truck is OOS right now....
Old Jul 20, 2009 | 09:21 PM
Franklin2's Avatar
Franklin2
I would swap flashers and see if the problem moves to the hazards.
Old Jul 21, 2009 | 04:13 AM
rmalottwtes30
Where is the flasher?
Old Jul 21, 2009 | 08:01 AM
ctubutis's Avatar
ctubutis
There are two flashers, both located in the fuse panel under the dash near the
parking brake pedal. I think the directional signal flasher is on the top-left corner
of the front of the fuse panel, the emergency-light flasher is directly behind it.
Two bolts to remove the fuse panel from the firewall.
Old Jul 21, 2009 | 08:34 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Also check the fuse for the turn signals.
Old Jul 21, 2009 | 08:39 PM
ctubutis's Avatar
ctubutis
Heh... Yeah, really... Is it plugged in, is it turned on,
is there paper in it....
Old Jul 23, 2009 | 12:17 PM
1Aauto's Avatar
1Aauto
Former Vendor
Wonder if the switch itself is acting up. He sell them on the site if you end up needing one.
Ford Truck Turn Signal Switch
Old Jul 23, 2009 | 06:08 PM
rmalottwtes30
I got it all fixed. I swapped out the turn signal unit in the steering wheel and also picked up a loud turn signal flasher unit.
