Delete Tuners
I have a 2015 F 350 6.7 Powerstroke and I want to drive with it the Panamericana. I`m afraid of all the emission systems of the truck and I want to know if I can delete them and if yes how. I found out that there are 2 tuners which can do that: Bully Dog SCT BDX and Minimaxx V2.
I have some questions:- Can I just delete only the EGR system with both tuners?
- Do I have to remove the DPF system physically when I only delete the EGR with both tuners?
- Can I reset the carsoftware back to the origin with both tuners?
- Is it possible to run the car with High Sulfur Diesel after deleting the DEF with both tuners?
- Can I delete trouble codes with these tuners?
- Which tuner would you recommend?
Thank you very much for your answers and excuse my bad english, I`m german.
What problems does "high" sulfur fuel cause in the ULSD designed systems of newer engines?
I hadn't posted again but was thinking he'd be best to delete with a stock power tune, test run it in Germany to check/solve any issues that arise...
EDIT... found this link about Diesel in Mexico. It's dated but it's a start for the OP...
https://bajamary.com/media/Mexico-Diesel.php
From 2019...
https://mexiconewsdaily.com/news/ext...sel-exemption/
This is more recent, from 2021... it appears Mexico keeps putting this off... a lot.
https://www.reuters.com/business/ene...es-2021-10-22/
Okay so there are known issues and this is for the OP because I don't know if he has seen this... from the product page.
Known Errors & Issues
On this page, we will continuously post the errors reported with the Mini Maxx V2 and the solutions.
Find the year and model of your truck and the solution to the error in the list below.
If you cannot find the error that your device shows you, please fill out the form below to contact us.
Be advised, that it may take a business day to get a response, and please check over all the known issues for a solution before you reach out. To avoid delays, make sure you fill out every field in the contact form.
*Do not send multiple emails unless you do not hear from us within 3 business days; sending multiple emails on the same day may trigger our spam filter, which will flag your email address and keep your messages from being seen.
*Please note: We do not offer any product support for the older version of the Mini Maxx. All information on this website only applies to the V2 tuner. If you have issues with a V1 tuner, you need to contact the company that you purchased it from for support. We cannot offer any support for the Mini Maxx V1.
>>>>There is a contact page form RIGHT HERE for issues so that's good to know...<<<<
Truck Model/Year and Errors
ALL VEHICLES: The Mini Maxx V2 does not support the factory pyrometer/EGT probes. Be sure to unplug all of them. If you need EGT readings you can add a docking station to the Mini Maxx.2011+ Ford Powerstroke: 1) Tuners with older software may throw a P24C6 or P24DA PMS code. This does not mean you did anything incorrectly, there is an issue with our previous calibrations and specific PCMs. As of October 2023, this issue has been fixed. If you are getting either of these codes, update your device. 2) Certain PCM software doesn't get along with our SOTF strategy and will not change power modes, this is rare and affects roughly 7% of the 2011-2019 Fords.
2016 Ford Powerstroke: The 2016 model year does not contain a PCV sensor that the MMV2 looks for resulting in a CEL for code P04E3. We have completed the fix for this issue, if you have this code you will need to download the fix file from HERE, extract it and copy the "MGGDT.IT1" file into the "FORD" folder on the SD card, then update the firmware on the tuner and reinstall the tune. Only download this file if your truck has the code.
Since it mentions this>>> If you need EGT readings you can add a docking station to the Mini Maxx.
I wonder if these will work since the MiniMax looks like a Bully Dog GT tuner...
https://bullydog.com/accessories/sen...n-w-pyrometer/
https://bullydog.com/accessories/sen...cking-station/
Last edited by Overkill2; Feb 15, 2024 at 08:59 PM. Reason: Add to post/add link for docking station install
These look to be the same so I guess you can also add different sensors to it... here's a link to the Bully Dog docking station here. There looks to be more inputs there in front...
From there:
"The Bully Dog Sensor Docking Station is designed to be the best and easiest way to integrate additional sensors with your Bully Dog GT tuner or Watch Dog system to monitor the performance of your Cummins, Powerstroke, or Duramax-powered diesel truck. The Sensor Docking Station expands the monitoring capabilities of your truck to display a wealth of information at your fingertips.
This Bully Dog Docking Station includes one Pyrometer and can support a variety of aftermarket sensors to monitor the following information:
- Speed
- Air intake temperature
- Boost pressure
- Oil temperature
- Oil pressure
- Transmission temperature
- Exhaust gas temperature (EGT)"
Truthfully, looking at those articles on the fuel in Mexico, and I'm sure it gets no better in Central America and South America, deleting is the way to go that's one less fluid (DEF) you have carry or try to find down there.
you can leave the EGR on and unplug it. It will fill with soot though. So going back to stock will mean having the EGR cleaned. removing it wasnt all that bad. just make sure you soak the exhaust bolts in your favorite flavor of rust penetrator the week or so before you start the work. especially when its nice and hot from being driven.
for that long of a drive i would HIGHLY recommend a flow thru muffler of some sort. nothing with any fiberglass packing, its gotta allow the soot to flow through and exit.
canada has great tuners, you should be able to find them via a simple google search. make sure you find a Proven Diesel tuner...
whatever handheld you go with will store the OEM tune. you should also save it to your computer.
i 100% will NEVER recommend GDP btw. their tunes came pre loaded and the shifting was horrendous.
