Steering wheel gap
Old Feb 10, 2024 | 09:09 PM
CH66's Avatar
CH66
1st Gear
Steering wheel gap
I’m at a loss. 66 F100. New cab mounts and bushings. Automatic with power steering. Huge gap between wheel and column. The bracket on the under side of dash is pushed up as far as it can go. Any ideas?
Old Feb 10, 2024 | 09:37 PM
RB-1963-F250's Avatar
RB-1963-F250
Are your new mounts and bushings somehow taller than the original?
Old Feb 11, 2024 | 12:52 AM
Christmas's Avatar
Christmas
If your lower column bearing is shot the column housing will creep down creating the gap.
Old Feb 11, 2024 | 04:39 AM
AZSCAWPION's Avatar
AZSCAWPION
Could be the lower column bearing as Christmas said, except in the case of worn lower column bearing, upward stress is put on the rag joint. As it stretches, the steering shaft moves upwards creating a bigger and bigger gap. If bearing is good then can be adjusted by pushing down on the steering wheel and tightening the clamp at the bearing. New cab mounts may just mean needs adjusting.
UncalTom73
2009 - 2014 F150
Oct 9, 2022 09:26 PM
snoozy
Jun 4, 2022 01:48 PM
touchfordtruck
Nov 20, 2016 12:10 PM
minkbigbird
Large Truck
Aug 30, 2015 08:25 PM
Kleenax
Mar 14, 2009 12:58 PM
