No crank
Old Feb 20, 2024 | 07:47 PM
ShortyF350's Avatar
ShortyF350
It was a new Motorcraft in the package. And yes it would get around 430-480 psi no matter how long I crank it. And the same reading with 3 different IPR's.
Old Feb 20, 2024 | 10:10 PM
bismic's Avatar
bismic
LOL - didn't answer the question ...........I can get "new motorcraft in the package" off of Amazon - and it is fake. I know - 3 different IPRs SHOULD confirm it isn't the IPOR, but the real issue is communication.
Specific questions, so specific answers would be nice. We ask for a reason..... and out of experience.
I take your answer to mean yours was from EBay or Amazon .................... if so, not good, probably counterfeit.
Old Feb 21, 2024 | 10:09 AM
ShortyF350's Avatar
ShortyF350
Originally Posted by bismic
I can get "new motorcraft in the package off of Amazon - and it is fake.
same pressure with 3 different ones
Old Feb 21, 2024 | 10:12 AM
bismic's Avatar
bismic
Cranking speed (rpm)?
Have you done an air test on the high pressure oil system, preferably w/ the valve covers off?
Unfortunately there are many threads on new standpipes being installed and their o-rings having been torn on installation - before the engine ever could start up.
Old Feb 21, 2024 | 10:37 AM
ShortyF350's Avatar
ShortyF350
did an air test with 150psi and It was good held pressure for atleast 10 min
Old Feb 21, 2024 | 11:23 AM
bismic's Avatar
bismic
IF:
  • Your HPOP is OK
  • You TRULY have no leaks
  • Your IPR valve is operating correctly
  • Your cranking speed is adequate
  • Your ICP sensor is working properly
AND, you still have inadequate ICP pressure to enable a start (ie .8 ICP sensor volts minimum and 500+ psi),
THEN it almost has to be a result of poor oil supply on the low side, or severely fuel-diluted oil.
Old Feb 21, 2024 | 03:26 PM
ShortyF350's Avatar
ShortyF350
Well thanks all for the help don't know what I am going to do now but I am not going to put any more money into it. Probably just park it in the yard .
Old Feb 21, 2024 | 03:31 PM
bismic's Avatar
bismic
Post a pic of the top of your engine. Maybe someone will have a brainstorm for you.
Old Feb 22, 2024 | 02:58 AM
ShortyF350's Avatar
ShortyF350
oil pump and turbo are off right now
Old Feb 23, 2024 | 10:51 PM
ShortyF350's Avatar
ShortyF350
All reassembled and still won't get much over 460psi and will not start. Showing code P2623.
Old Feb 23, 2024 | 11:28 PM
Jokester00's Avatar
Jokester00
P2623 is an IPR circuit open code. It can be either the IPR itself or the plug/wiring.Was this code present before you replaced the IPR's?
What is your ICPvoltage KOEO and when cranking?
-jokester
Old Feb 23, 2024 | 11:54 PM
ShortyF350's Avatar
ShortyF350
Did not check code before all this. But the plug was changed and now I wonder if the wires are backwards.
Old Feb 24, 2024 | 12:04 PM
  #28
Jokester00's Avatar
Jokester00
That's a possibility. I'd clear the code and see if it comes back.
If the code doesn't clear, use the attached procedure...
-jokester
File Type: pdf
Old Feb 24, 2024 | 12:05 PM
  #29
bismic's Avatar
bismic
The IPR should should work wired either way. Simple on/off wiring (pulse width modified signal ).
A non-working IPR would not allow you to pass the air "leak test" if testing through the ICP sensor port (or an oil rail port).
As discovered - checking codes early can really cut down on the troubleshooting effort.
Old Feb 24, 2024 | 12:12 PM
  #30
Jokester00's Avatar
Jokester00
While I agree with you, i'd also want the wires in the correct spots for future troubleshooting so I or someone else don't end up chasing my/their tail with confusing results.
-jokester
