Poorly Painted Mess
Old Feb 7, 2024 | 02:16 PM
Hudson Wade's Avatar
Hudson Wade
Poorly Painted Mess
I have a 1965 F-250 Custom Cab, and I love it. It's actually my daily, as inefficient as it might be. It's my first vehicle, and also the first time I've properly worked on a vehicle. As crazy as that sounds, I got the truck going and it has been incredibly reliable. It starts every time, even in the 20-degree weather we've been having. Now that the truck is relatively mechanically sound, I'd like to begin a bit of restoration on the interior and exterior. I have a clear plan for the interior that involves a repaint, floor pan repair, and some instrument cluster revamping. However, I'm wondering what I should do on the exterior.
The truck's body panels are in pretty good shape. There are some dents and dings, and the driver's door is slightly crunched on the front, but overall, pretty good. However, the paint is rough. Well, not really. The truck's original paint seems to be in great shape. However, someone did a bang-up repaint over the original paint (but in the same or similar color), and it's flaking off. Here are some pics:
Just an overview of the body
On the hood
The roof
And haphazardly (brush?) painted around the chrome
So, my question is, how can I go about getting this off with minimal damage to the original paint? I'd like to get the truck looking good enough to clear coat and maintain the original patina and paint because I like that. If I can't I'll just paint it, but I don't like that.
That's It! Thanks!
Old Feb 7, 2024 | 06:58 PM
Ohmthis's Avatar
Ohmthis
Pick a inconspicuous spot and test different solvents. Start off with less aggressive solvents and work up to harsher ones. You may find that something on a fine scotchbrite pad may remove the crappy paint. I agree that it looks like someone used a brush. That’s a cool truck!
Old Feb 7, 2024 | 07:57 PM
Hudson Wade
Do you have any recommendations for sale events?
Old Feb 7, 2024 | 08:46 PM
wtx66f100's Avatar
wtx66f100
Thinking I would try a pressure washer first and see just how much of that second paint job would strip off.
Old Feb 7, 2024 | 10:14 PM
Hudson Wade
Solvents! Voice type doesn't work for everything 😂
Old Feb 7, 2024 | 10:16 PM
Hudson Wade
Oh, why didn't I think of that! Great idea. Once it gets above freezing here I'll try that out.
Old Feb 8, 2024 | 11:18 AM
Boss9F100's Avatar
Boss9F100
On the hood
The roof
That's It! Thanks!
A steam clean will remove all that excess paint without hurting the paint underneath
Old Feb 8, 2024 | 12:22 PM
theastronaut's Avatar
theastronaut
Graffiti remover and oven cleaner are popular picks when removing non-original paint to get back to the original paint on the VW forum. Worth a try on a small area.
Old Feb 8, 2024 | 04:26 PM
KO1960's Avatar
KO1960
The Vice Grip Garage trick of using SOS pads with soap works pretty well after a pressure wash, if you’re after a patina look.
Old Feb 8, 2024 | 07:05 PM
Order and Chaos's Avatar
Order and Chaos
The way that paint is checkering, it reminds me of really old house enamel paint on wood. As it gets sun baked the paint physically shrinks, separating in to little squares. If you're trying to preserve any original paint underneath I'd avoid using a petroleum based thinner (acetone, MEK, etc) to remove the top layer. Also be extra careful with a power washer, get too close with the spray nozzle or hit the paint with too much water pressure and you'll pull off the original paint along with the bad repaint. Depending if you're going for a patina look, a sturdy soft sponge used carefully with water & a little Comet may remove most of it, but it will take a long time.
Old Feb 8, 2024 | 10:52 PM
Nevada51's Avatar
Nevada51
Once you've done the pressure wash, Acetone and a lot of rags is the answer, but wear gloves and an appropriate mask. The original paint is very resistant to the acetone. Oven cleaner didn't ever work well for me, or graffiti remover for that matter. Any mechanical scrubbing should be a last resort if you want the original paint left in good condition. I have done this with several cars and trucks with great results....but it takes a long time, so just be patient. Of course there may be a reason your truck was repainted in the first place, so you may uncover bondo etc.
Let us know how it goes.
Old Feb 11, 2024 | 11:05 AM
Hudson Wade
The good news is that there's patina already, with soen surface rust showing through. I just need to get the ugly paint off. Thanks for the advice, though!
Old Feb 12, 2024 | 07:04 PM
FuzzFace2's Avatar
FuzzFace2
I would go with power washing first.
I dont think I would use and liquid type stuff to remove the old paint or even SOS pads / scotch pads as it will hurt the factory paint.
With out seeing it in person kind of hard to say just how to go about this other then power wash.
Oh I dont see the PW taking the factory paint off.
Dave ----
Melnickta
Dec 28, 2021 04:17 PM
Tparkin99
15
May 15, 2016 07:27 PM
emeraldcoupe
May 28, 2015 11:27 PM
cbass139
Paint & Bodywork
Jun 4, 2009 12:05 PM
