Sponsored by: Auxito
Theft alarm----- What does it do?
Old Nov 24, 2003 | 11:11 AM
Rusty1's Avatar
Rusty1
I have a 1999 F-150 4x4 (which I'm sure we all have the same alarm system) and I was woundering what the "Theft Alarm" system is all about.
I have a blinking light when ever the ignition is off. Does that mean it's activated? When I lock the doors and the horn beeps, is that when it's on?
What does it do for you? Can the truck still be hot wired?
The manual doesn't tell you anything.
Can anyone explain it?
Should I stll buy an after market system?
Old Nov 24, 2003 | 11:35 AM
LxMan1's Avatar
LxMan1
Mine does this too, but it doesn't actually have an alarm on it. I think this just means that the pass-key system is armed so that you must use the correctly coded key to start the truck. I can open the door from the inside with the system armed and it doesn't alarm.
Jimmy
Old Nov 24, 2003 | 12:01 PM
Rusty1's Avatar
Rusty1
lxman1
Thanks for the reply. I've wondered about that.
Rusty
Old Nov 24, 2003 | 01:40 PM
leroys4wd's Avatar
leroys4wd
my 2003 F-150 4x4 theft light flashes when the ignition is off, but I have to activate the alarm by pressing the lock button on the remote twice. It beeps the horn to let you know if it's activated and if you open the door (I tried it with the window down, simulating someone breaking the window and unlocking it by hand) it starts beeping the horn and flashing the lights until I disarmed it by hitting the unlock button.
Old Nov 24, 2003 | 02:19 PM
Rusty1's Avatar
Rusty1
Really---I'll try that tonight----hummmm
Thank you
Old Nov 25, 2003 | 07:37 AM
LxMan1's Avatar
LxMan1
Mine doesn't do this, I tried that too.
Jimmy
Old Nov 25, 2003 | 07:52 AM
leroys4wd's Avatar
leroys4wd
lxman1, does yours chirp the horn when you press "lock" twice? or does it just not beep when you open the door?
Old Nov 25, 2003 | 09:57 AM
leroys4wd's Avatar
leroys4wd
sorry guys, bad info - mine doesn't work either. I had a '96 Explorer that did that and just though this truck would be the same, it's not. It does nothing when I open the door with the alarm enabled.
Old Nov 25, 2003 | 11:10 AM
CPerry's Avatar
CPerry
Mine doesn't do anything either. Maybe when the door is electronically unlocked, it disarms the anti-theft system???
Old Nov 25, 2003 | 11:22 AM
Rusty1's Avatar
Rusty1
Well, as long as the "Bad-Guy's" don't read this, they'll think there's an alarm system (Flashing light) and leave our truck's alone. They'll then go break into a chevy or something.
Old Nov 25, 2003 | 11:27 AM
leroys4wd's Avatar
leroys4wd
now I feel like an idiot for making the horn blow everywhere I park it thinking it was actually going to do something. quick, mediators, pull the plug on this thread so nobody figures out the alarm system is no better than the "protected by Smith and Wesson" sticker on the door. LOL! I am going to call my dealer and see if I can find out if the thing actually does <i>anything</i>
I called the dealer service department and they said it beeps the horn and flashes the parking lights to let you know the door is locked, it does absolutly nothing else. It is, in fact, a fake alarm.
Old Nov 25, 2003 | 12:39 PM
Rusty1's Avatar
Rusty1
leroys4wd
Thank you for researching that for us. I've always thought it did something besides "beep" and scare the-- #$%--- of of others walking in front of your truck (that's fun to do). Now I'm going to go shopping for a new system.
Anyone have any suggestions?
Rusty1
Old Nov 25, 2003 | 05:57 PM
LxMan1's Avatar
LxMan1
Yep, that's exactly what mine does too. My theft light doesn't flash if the doors are locked with the remote.
Jimmy
Old Nov 25, 2003 | 09:15 PM
aldridgec's Avatar
aldridgec
The horn is just a lock confirmation so you can check the truck recieved the signal to lock the doors. The theft light is a status light for the PATS system and is used to also indicate a malfunction and programming.
There is no FAKE alarm on this. Earlier trucks, like your 96 had a perimiter intrustion system. But I believe with the PATS system this was eliminated. The PIS was not an alarm that would defeat the theft of the vehicle as far as I know. An aftermarket alarm will probably do you little help for slowing intruders IMO other than providing a perimiter alarm. I would recommend the ford GOLD remote start system. If you are going to hack up your truck wiring for an alarm you might as well add remote start too. It will look like a ford remote, add a perimiter alarm with siren and a remote start that has a module to work with the PATS without using your spare key under the dash (really secure for other to do that you know !)
Old Nov 26, 2003 | 12:48 PM
MrBSS's Avatar
MrBSS
I second Aldridgec's suggestion. It provides a high level of security and everything works as it did. But,... it's a big installation, so don't try this at home, kids, unless you're really good!
