Under floor brake booster
Old Feb 2, 2024 | 07:37 PM
Kerry A's Avatar
Kerry A
7th Gear
I' m looking to upgrade my 55 F-100 to disc front and drum rear. Has anyone heard of or used the Performance Online Kit #BBX-T5356? It's a power booster kit for under floor unit which states kit mounts where original master cylinder mounts. Also being able to use original brake pedal. This is a bolt on kit with no fabrication needed. Any information would be greatly appreciated. Thanks
Old Feb 2, 2024 | 08:02 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Have not used the kit you mentioned but I have the No-Limit Engineering kit undet my floorboard that uses the Mustang II booster and m/c. It uses the stock pedal and pedal location. Been there for over 25 years and never an issue. I love it.
Old Feb 2, 2024 | 08:18 PM
Kerry A's Avatar
Kerry A
7th Gear
Thank you for the information I'll definitely check out the kit.
Old Feb 2, 2024 | 09:52 PM
pappacrunch's Avatar
pappacrunch
Not sure about this kit. I have one under the floor from CPP with the power booster and had to add a remote fill kit as the hole in the floor didn't line up with the fill tank. Not the end of the world but just something to be aware of. Also if you will need the residual pressure valve as the disc and drums use different pressures. Disc use 2lb and drums at 10lbs. Including a pictures of mine. The remote fills are the aluminum CNC's by the Ace of Spades sticker.
Old Feb 3, 2024 | 08:42 AM
F100supercrew's Avatar
F100supercrew
booster
Go CPP firewall mount power booster for your year truck-- Best thing since slice bread---Go to there web site--Doing this all these years the under floor set-up SUCKS---
Old Feb 3, 2024 | 09:25 AM
Old F1's Avatar
Old F1
I have to agree.
Two of the last four cars / trucks that I built had under floor and I am sure it was my fault but they never worked right.
My next (and last) project will have fire wall mounted master cylinder and booster.
I have come to keeping it simple without the stress over appearances that few will see and even fewer will care.
Do what you want to do and live with it.
ron2565
May 5, 2022 05:10 PM
man7sell
Jan 29, 2018 03:18 PM
Mr. Ed
Jun 24, 2016 02:26 PM
BigB9000
Sep 17, 2013 08:44 PM
Gwilkrrs
Apr 8, 2006 12:00 AM
