brake booster pedal assembly
Old Apr 7, 2006 | 07:33 PM
Gwilkrrs's Avatar
Gwilkrrs
looking at replacing my brake system.on my 51 f1
anyone use any kit special?
if so did you need to replace the factory crossmember with and aftermarket trans mount?
Old Apr 7, 2006 | 08:19 PM
g84t8f1's Avatar
g84t8f1
I put power brakes on my 48 F1.I had to use the factory crossmember so I could use my stock pedal.I had to cut out the crossmember so my tranny would fit.I also made a mount to bolt it to.This was a kit to use mustang2 brake booster and master cylinder.I can post a pic later if it will help.
ART
Old Apr 8, 2006 | 12:00 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
I got rid of the factory trans x-member. I used the trans x-member out of my donor car, a 72 Caddy to mount the TH400.
I made my own hanging brake pedal assy using a pedal, pivot, and spring assy from a late 90's Ford focus. I also used the power booster from the focus. When I made the pedal assy I made sure to connect it to the firewall, dashboard, and steering column. I mounted a late 70's GM Master cylinder to this and so far it seem to work pretty good.
I also added a line-lock solenoid into the system....just for grins
Bobby
