4.9 or 5.0
Old Feb 1, 2024 | 06:23 PM
tamcphail's Avatar
tamcphail
4.9 or 5.0
I have a 94 rcswb, 5.0 5 speed with 3.55's. I'm trying to decide whether to rebuild my 302 or I've tossed the idea around of building a healthy 4.9 and swapping it in. It's partly nostalgia cause that's what I learned to drive on, and it's something different than every other 302 or 351 build.
It's just a street beater truck, I don't haul anything or go off road. It's not even a daily driver.
Which direction would you guys go and if it's the 4.9 route, what cam and head would you go with to bump up the power?
Thanks all
Old Feb 1, 2024 | 08:13 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Seems like you’re already made up your mind about swapping to a 300. Hopefully you can find a ‘94 factory 6 cylinder wire harness and computer. Rebuilding and upgrading the 302 would be a lot easier and make more power. The 6 is a good engine but it’s not for me. At 295K miles I replaced the 302 in my ‘87 Bronco with a 392. I am still working on the ‘89 F-150 frame off rebuild but I replaced the worn out 302 with a 351W in that truck.
Old Feb 1, 2024 | 08:17 PM
tamcphail's Avatar
tamcphail
I honestly am ok with either direction. I love the 300 but I also love the 302 and how it sounds. I can get a donor 300 for free with all the EFI and harness but I'm not positive it's from a 94. If I stick with my 5.0, I'm gonna carb swap it
Old Feb 1, 2024 | 08:31 PM
My4Fordtrucks
Why would you do that? The factory system can work with performance upgrades. You will not only have to deal with the ignition system but also the fuel system to step it down to a carburetor friendly pressure.
Old Feb 1, 2024 | 08:32 PM
tamcphail's Avatar
tamcphail
I'm speed density, not maf. Not many sd friendly cams out there. Plus I like the look of a cleaner engine bay
Old Feb 2, 2024 | 01:29 AM
AuroraGirl's Avatar
AuroraGirl
a 302 is going to be woken up from mechanical changes more than electrical. A carb is going to still be a low output motor unless you do mechanical work .
Old Feb 2, 2024 | 01:30 AM
AuroraGirl's Avatar
AuroraGirl
I vote for 4.9, but Im partial to them since I have one. What year is the 4.9? 80s were less reliable than the 90s, and I believe 92 or 94 they got a roller camshaft. And 96 got OBD2 but 94 got MAF I think.
Old Feb 2, 2024 | 02:48 AM
tamcphail's Avatar
tamcphail
Mid 90's pickup motor. It would be a full rebuild
Old Feb 2, 2024 | 03:39 AM
AuroraGirl's Avatar
AuroraGirl
if it is mid 90s (94, 95, 96 ) it should be roller cam and maf (both 5.0 and 4.9 I believe would be like that)
I am saying its a good idea. If you do, i hear a metal timing gear is a good swap but it makes it noisier. Because the phenolic OE one can wear more over time or fail.
Old Feb 2, 2024 | 04:13 AM
My4Fordtrucks
I assumed it was speed density since you have a 5 speed. There are better roller cams than what is currently in the engine but still computer friendly. There are dozens of threads. Short or long tube headers with a better flowing exhaust system will help.
Old Feb 2, 2024 | 06:00 AM
JJF20's Avatar
JJF20
Which direction would you guys go…
It sounds like you want better performance, yet step backwards / smaller at the same time?..
Different EFI 300 engine or 302 and carb, intake, modify fuel system, etc. You’re ok with the EFI on the 300, but not the 302? I don’t understand why?
Imo, EFI 302. Or go bigger, EFI 351 and build to suit the performance you are looking for. Clean up the engine bay, paint it, clean up the wiring nicely, etc.
Personally, I just can’t imagine going back to a carb, ..unless it’s an original carb car/truck and you want to keep it all original.
I’d start reading through threads on here before you decide, you might like some of the other options out there.
Good luck in the project.
Old Feb 2, 2024 | 09:23 AM
tamcphail's Avatar
tamcphail
I love the 300 motor and the low end that it has. And as far as the going to carb, i am not a fan of SD at all and i figured it'd be simpler to just switch it to carb.
Old Feb 2, 2024 | 11:14 AM
AuroraGirl's Avatar
AuroraGirl
while speed density isn’t as good as maf, it’s also still pretty good when you have everything in proper order. Factory eec-iv speed density never killed no one and moves many trucks happily down the road
Old Feb 2, 2024 | 12:42 PM
Scndsin's Avatar
Scndsin
Very popular misconception. Otherwise you could find dozens of success story threads instead of "I'm going to do it anyway against all advice..."
And never heard from again.
Old Feb 2, 2024 | 12:58 PM
Hit Man X's Avatar
Hit Man X
302 will make decent power with heads, the E7s are garbage. They barely flow past 150cfm intake side around 0.500"...yah lame. Stock SD relies upon engine vacuum to meter fueling, easy...so you need to understand camshafts to make one produce similar or more vac than stock. Simple. You can easily add 20-30* dur at 0.050" and 0.100" more lift with modest off seat events and LSA to keep it tame. Remember 87-88 302HO were speed density too.
Anyway, the 4.9 needs a pile of work to make power. The EFI setup is nearly maxed out stock to run on cheap fuel and pass smog, you can do a modestly spicier camshaft and home port the head, but that is about it.
I have both and Diesel. Just depends what you prefer to drive about.
