Engine Build Part 2: The Assembling
Old Nov 11, 2024 | 02:52 PM
  #61
PriusLover's Avatar
PriusLover
Portland. I've also heard there are good shops in Idaho... was even given the name of a couple by people here who take their blocks out there to get done up.
Old Nov 25, 2024 | 01:33 AM
  #62
PriusLover's Avatar
PriusLover
Old Nov 25, 2024 | 10:45 AM
  #63
JoshHefnerX's Avatar
JoshHefnerX
You being a tease now?
Lol
That surface finish almost look too smooth. What's left to be done?
Old Nov 30, 2024 | 02:15 AM
  #64
PriusLover's Avatar
PriusLover
It's actually just right:
Only real things left to do is get one cylinder checked out (few rust spots have developed) and buy a camshaft.
Old Jun 13, 2025 | 10:07 PM
  #65
PriusLover's Avatar
PriusLover
Oh my god an update! Should have a new flange welded on the pan by next week.
I also finally ordered the cam.
Old Jun 14, 2025 | 01:01 AM
  #66
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Dude. Is that device finding the flatness of the cylinder head by measuring variation of the magnetic response from the surface? Is the "Eval Length" depth or width of scan?
I've measured metal many ways but never flatness, other than with a straight edge.
Old Jun 14, 2025 | 01:07 AM
  #67
PriusLover's Avatar
PriusLover
It's a profilometer for measuring surface finish/roughness. I'm not sure a device exists like you're describing; closest would be a Talyvel which is like a super precision pendulum for sensing tilt.
Old Jun 14, 2025 | 01:50 AM
  #68
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
The flatness of reflective surfaces, such as the machined head shown, can be measured in wavelengths of light, down to a resolution of just 1/3rd of a micron.
Old Jun 14, 2025 | 11:54 AM
  #69
Dan V's Avatar
Dan V
..... Is the "Eval Length" depth or width of scan?
My guess is "Eval length", which shows .030, is the length of the stroke of the probe.
Old Jul 1, 2025 | 12:18 AM
  #70
PriusLover's Avatar
PriusLover
Cut out and repurposed the weld in dipstick adapter. Flange is 1/4 thick flat bar. Five pieces welded together.
The oil pickup was huge pain. It needs to clear the top of the bed plate nuts (which have absurdly tall washers under them) while also not touching the windage tray in the stock oil pan, all the while having a similar internal cross sectional area as the stock tube so that flow isn't restricted. Ended up buying some round tube, pressed it about half an inch tall in the h-frame press (I did it in stages between the press plates hence why it's not entirely uniform). Then bent/hammer formed the front side, which connects to rectangular tube which itself connects to the stock tube flange that bolts to the front cover. The rear of the tube is the stock foot with some bridging to help it connect to the flattened tube without causing a restriction.
Overall took several weeks to conceptualize and fabricate and was a constant frustration. That being said my total cost for materials and welding was around 200 which is quite a bit cheaper vs the ~1700 it costs for a hypermax pan and pickup (worth noting their pan doesn't have a windage tray which seems like a weird omission).
Old Jul 1, 2025 | 07:10 AM
  #71
Dan V's Avatar
Dan V
I would try and fashion a support for that pickup area that is hanging nearly a foot out into space.
Old Jul 1, 2025 | 08:56 AM
  #72
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
If I were going through all of that trouble like you are, I would definitely have that engine as my headstone. I just hope the vehicle surrounding the engine you are building will last as long as you hope it does.
Old Jul 1, 2025 | 09:25 AM
  #73
PriusLover's Avatar
PriusLover
Newer trucks are so incredibly ugly and communicate a pathetic "I'm afraid of everything outside the window" with their engorged aggro stylings. That and all the smart crap in newer vehicles are just a couple reasons why I'll be holding on to this thing for as long as I can.
Old Jul 1, 2025 | 10:47 AM
  #74
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
That, and half your 401K is already invested in rebuilding the thing. You have no choice but to hold on to it.
If when it finally gets finished: Send it straight to Sotheby's.
It will be the most exclusive, exquisitely built examples of the 7.3L PSD in existence in the entire world.
Make your money back, and then some, beating the DJIA for the same number of years (decades?) of invested principle, and then splurge on an engorged aggro styled Stryker.
(Fancy hospital bed.)
All teasing aside, the community at FTE has been fortunate to have been given a bird's eye view of your build journey, where you have brought an attention to detail uncontemplated by many, and only attempted by few.
Old Jul 1, 2025 | 02:43 PM
  #75
FordTruckNoob's Avatar
FordTruckNoob
I can trade a 2000 PSD for this? Sign me up.
PriusLover
19
Apr 16, 2025 05:16 PM
Christof13T
1983 - 2012 Ranger & B-Series
22
Jan 9, 2024 12:35 PM
7.34x4
Feb 13, 2021 06:42 PM
kopfenjager
Mar 19, 2020 03:27 PM
JPs2003
Aug 11, 2018 02:29 PM
