2000 V10 throwing fuel mixture lean code
Old Jan 28, 2024 | 11:26 PM
Bill4042's Avatar
Bill4042
Let my wife drive the Excursion for a couple of days so of course it’s now giving me lean fuel codes PO171 & PO174. Anybody know one or more specific fixes?
Old Jan 29, 2024 | 05:41 AM
MoBill122's Avatar
MoBill122
Papa Smurf
Run some injector cleaner thru it.
Clean the MAF sensor
Look for any leaky vacuum lines
Old Jan 29, 2024 | 05:45 AM
charlie g's Avatar
charlie g
FTE Community Team
unmetered air, dirty mass air flow sensor, weak fuel pump, how many miles?
Old Jan 29, 2024 | 09:24 PM
Bill4042's Avatar
Bill4042
Miles, Lucas
It’s at about 486K right now, used to put Lucas in regularly after I cleaned the throttle body at 117K, hasn’t needed cleaning since. But I’ve got some Lucas, so I’ll stick that in the tank now.
Old Jan 29, 2024 | 10:13 PM
R&T Babich's Avatar
R&T Babich
Originally Posted by Bill4042
.... it’s now giving me lean fuel codes PO171 & PO174. ....
Both lean codes leads me to think there is a vacuum leak between the MAF and the intake manifold.
Check the PCV hose for cracks/softness, especially the last few inches where it connects to the engine.
Check the air intake plenum between the MAF and throttle body for cracks/leaks.
Check the throttle body and IAC gaskets.
Do you clean the MAF regularly?
Glsawyer
Oct 9, 2023 07:16 PM
Brian Lewis
Jun 2, 2023 01:08 PM
Fordman121676
Jun 25, 2021 05:59 PM
Big_D_v10
May 31, 2011 06:35 PM
Baja Daze
Modular V10 (6.8l)
Mar 16, 2004 01:26 PM
