Modular V10 (6.8l)
V-10 Trouble Code???
Old Mar 12, 2004 | 08:57 AM
Baja Daze's Avatar
Baja Daze
On a 2000 f-250 with a V-10, the "check engine light" came on. The truck was taken to an auto parts store to test codes and it said "po171 too lean bank 1" and "po174 too lean bank 2." Any ideas what this could be??
Thanks in advance for any help.
Old Mar 12, 2004 | 02:26 PM
Mark in AZ's Avatar
Mark in AZ
I just went through those codes on 2 V10s I've purchased in the past 6 months (I'm a wholesale dealer here in AZ). Check 1st for a vacuum leak. The rubber hose (about $20) that goes from the passenger side valve cover crank breather up to the intake tends to split where it does a 90 degree bend right up at the intake. Some have said that EGR sensor (about $50) could cause it too but my most recent truck had a fuel pump that was dropping pressure and had to be replaced ($192pump + $185labor). Good Luck.
Old Mar 15, 2004 | 08:38 AM
Baja Daze's Avatar
Baja Daze
Thank you very much for the response. We'll look into these possibilities.
Old Mar 16, 2004 | 08:34 AM
Baja Daze's Avatar
Baja Daze
Mark, you were right on!!!! It was a vaccuum leak caused by a crack in the 90 degree bend. Many thanks.
Old Mar 16, 2004 | 09:01 AM
Big Orn's Avatar
Big Orn
This is a common problem on 99 thru 01 models. It may start showing up the the newer V10's before long. That 90 degree ell is made of some sorry stuff.
Also, you can't tell by just looking at it - it collapses during acceleration.
Old Mar 16, 2004 | 01:21 PM
Baja Daze's Avatar
Baja Daze
Interesting...Sounds like it needs some re-enforcement in the rubber to stiffen it. It's probably failing from bending fatigue.
Old Mar 16, 2004 | 01:26 PM
Big Orn's Avatar
Big Orn
I think it's mainly the material quality and not structural design. I put a straight hose on after the collapse, but it was a bad idea. I went ahead and put another OEM part on for now, but will probably find some other solution (SST Ell, maybe) with an adapter hose to put on next time.
Baja - I could take mine and put my finger into to and it stretched about 2" after it failed. It was like a balloon.
Nothing Special
Nov 16, 2016 05:54 PM
jdavidsmi
Modular V10 (6.8l)
13
Jun 4, 2016 10:18 AM
Mr f250
Feb 21, 2016 11:25 PM
Marty1965
1997 - 2003 F150
Apr 21, 2015 01:31 AM
rocky3539
Apr 20, 2007 03:52 PM
