Radio Support Bracket?
Old Jan 28, 2024 | 12:02 AM
Eagle-F1's Avatar
Eagle-F1
I'm working on installing a stock radio (well at least the case is) in my 1952 F1. I'm wondering what sort of support bracket should be installed at the rear or sides of the radio. I see a bolt hole in the back of the radio but don't see anything obvious above it to connect to or hang from. It seems to me that just having it hang from the front ***** is not enough support. Any pictures or advice? Thanks.
Old Jan 28, 2024 | 12:21 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
The shop manual has a few pages around radio installation and whatnot. One of the many figure shows a mounting bracket at the rear:
Additionally, Ford offered various radios and adapter kits so there may be variances.
Old Jan 28, 2024 | 10:13 PM
52Flthed's Avatar
52Flthed
I noticed you said “at least the case is”. Meaning that you had a digital conversion done? If so, a lot of times they will shorten up the original radio’s case. Either way the radio is much lighter without all the old tubes and stuff. Mine was capable of just supporting itself on the shaft *****. But what I had done just to be safe, on the 2nd installation was a custom support bracket as my case was drastically smaller than the original and also we made up a water cover as the radio sits right under the cowl vent which tends to leak water.
Old Jan 29, 2024 | 12:47 PM
Eagle-F1's Avatar
Eagle-F1
Glad you asked. Actually I'm doing my own thing. I threw out the old guts which were dead and just kept the case and the dial support stuff. I installed a '90s AM/FM radio that I picked up at a swap meet for $5 inside the case. I'm still fighting with the system to get it working right. The dial ***** are on six inch centres on the new and seven inch on the old. I connected them with GT2 timing belts and pulleys. I 3D printed all necessary supports and connectors. The truck is 6V positive and the radio is 12V negative so the internal radio has to be completely isolated electrically. I also have a cheap $27 Chinese radio that comes with bluetooth, USB, etc. that I'm hiding in the glove compartment and I want both systems to share six inch speakers in the kick panels via a four channel relay. It's a challenge that I'm still working on. So far the radio works great out of the truck, the presets work except the right one controls AM/FM, the dial needle moves in sync with the tuning. I used 50 lb. braided fishing line for stringing. From the outside the radio looks exactly like Henry made it.
Old Jan 29, 2024 | 12:48 PM
Eagle-F1's Avatar
Eagle-F1
Thanks. That's what I was looking for.
Old Jan 29, 2024 | 01:08 PM
52Flthed's Avatar
52Flthed
Wow sounds like you’ve got some great determination to get this done. Good for you keeping it stock and pos 6v ! My radio is 12v but has a built in converter, truck is 6v pos ground using a single mono 6x9 speaker in stock location. It plays nice and loud, work well , takes calls too, but certainly wouldn’t please an audiophile.
Old Jan 31, 2024 | 11:11 AM
1PieceAtATime's Avatar
1PieceAtATime
What a great idea! OE appearance and modern functionality, inexpensive and DIY ! ( I had to look up what an "antenna trimmer" is LOL )
magicrat56
13
Jun 3, 2023 06:57 PM
hentzrd
13
Feb 14, 2022 06:07 PM
Vsanzbajo
WTB - Parts & other
Sep 18, 2013 08:18 PM
Shadowrider123
16
Nov 15, 2012 06:27 PM
Sayer Lane
Jun 28, 2009 11:36 AM
