question on rear diff
Old Jan 26, 2024 | 07:49 PM
mackendw's Avatar
mackendw
My 87 ford f150 5.0L rear differential has a bit of play in it. when cleaning/adjusting the rear brakes last fall, I noticed when I had the wheels up in the air
that there was what I considered excessive play when rolling the wheel back/forth for the gears to engage. Is this play the pinion/ring play? or would it
be worn bearings in the carrier or pinion? I picked up a master rebuild kit for the rear diff but don't want to fire the parts cannon at it ***** nilly.
Anyone share some words of wisdom here as to when a teardown is warranted here? There is no noise coming from it when driving, just a clunk when
putting it it reverse usually as the gears engage. Drive doesn't seem to do that as much.
thx a bunch.
Old Jan 26, 2024 | 11:53 PM
TobyB's Avatar
TobyB
Usually it's a combination of wear everywhere.
You have to go through it part by part to see if any one thing's worn too
badly, or failed. The needles came out of a driveshaft on one of our
vehicles once, and I was shocked that the only real symptom was the
clang when I went to back up...
t
Old Jan 28, 2024 | 08:20 AM
rla2005's Avatar
rla2005
If you have a factory limited slip rear axle the extra play can also be triggered by worn clutch plates.
Process of elimination. A thorough inspection is in order.
Old Jan 28, 2024 | 08:25 AM
mackendw's Avatar
mackendw
axle code 18 - open / conventional diff.
Old Jan 28, 2024 | 08:54 AM
AuroraGirl's Avatar
AuroraGirl
3.08? im so sorry. if I were you I would drop the rear cover and inspect and put new fluid in while at it. If you decide you want to go back in there, make a plan of it. Regardless of what you do, I recommend an elastomeric gasket like this :
superior to paper, rtv, rubber etc.
Old Jan 28, 2024 | 09:16 AM
mackendw's Avatar
mackendw
when I picked it up in 2021 I had all fluids replaced with new gaskets. I'll wait a bit before diving into it as it's not yet too bad. Just ease it into gear.
Old Jan 28, 2024 | 10:05 AM
Conanski's Avatar
Conanski
Some slack in the rear is considered normal, there are a bunch of moving parts in the diff where a little play in each one adds up a fair bit at the axle ends. Does that truck have an AOD trans? if so the OD is practically useless with that axle ratio, the truck will perform much better and get better gas milage with 3.55 to 4.10 gears, so if you do decide to rebuild the diff consider changing the gear ratio at the same time.
Old Jan 28, 2024 | 11:29 AM
Hit Man X's Avatar
Hit Man X
I run a 275/60R15 with my AOD/302 and 4.10:1 gears. 70mph is about 2300RPM only. 100% agree with Conan.
Old Jan 28, 2024 | 12:23 PM
mackendw's Avatar
mackendw
nope...C6 - 3 speed tranny
Old Jan 28, 2024 | 12:47 PM
85e150's Avatar
85e150
If it's not making noise or leaking, leave it alone. You can check the bearing and pinion areas for excessive heat if you are worried about a bearing, but they will almost always be making noise if bad.
Swerving suggestion.....
Old Jan 28, 2024 | 06:43 PM
AuroraGirl's Avatar
AuroraGirl
if you dont mind your mileage then you may want to keep that, but if i were you id try to get a 4 speed
4r70w or e4od swap when ? lol
TonyJestis
15
Nov 5, 2012 06:13 PM
devozoo
1997 - 2003 F150
16
Feb 1, 2011 05:58 PM
ladewigm
Oct 4, 2003 07:01 PM
ETB1
May 28, 2001 01:10 PM
