2023+ Super Duty ForScan Spreadsheet
#136
Success!! I have successfully restored the display of Nav data (turn by turn instructions, etc) over the HUD system in my 2024 F350 Lariat w/Lariat Ultimate Package !!!
APIM As Built Address and Configuration Register Values
7D0-05-01 2586 0400 008C
Made this edit:
7D0-05-01 x6xx xxxx xx—
Resulting Address and value:
7D0-05-01 2686 0400 008C
I cycled the ignition, then after the infotainment system reinitialized, I reset the APIM by pressing and holding the audio power button (i.e. the volume "off" ****) and the forward seek button (>>| ) simultaneously.
Now, the Nav data is displayed on the 2024 F350 Lariat w/Lariat Ultimate Package HUD like it used to be for my early 2023 F350 Lariat w/Lariat Ultimate Package!!! Yay!!
100% of the credit goes to ZooDad who investigated on his own time and after I sent the 2023 and 2024 F350 As-Built Data from Ford, was able to tease out what needed to be changed. Thanks a lot to ZooDad!
Late edit: I can also confirm that Google Maps and Waze also once again display their Nav instructions over the HUD via Android Auto. I don't have an Iphone so I can't test that functionality, but I imagine that will work too.
Made this edit:
my as built for that line is:
7D0-05-01 2186 0400 0088
'24 F250 lariat ultimate 7.3
#140
#141
Goals:
*LED reflector head lights to LED Projector head lights with auto level and turning
*I'd also like to change the tails from partial LED to FULL Led.
*Power step operation one side at a time
*Power generator default to Off on start up
#142
#143
It will take miles to update. I did the same with my 2017 when I went to a 55 gallon Titan. Made the change with Forscan and it wasn't much of a difference in DTE. After a few hundred miles, it corrected itself. I was worried for a while but other members who did the same told me to wait it out and it corrected in time.
#144
#145
#147
#150
Probably a dumb question.
I was attempting to modify the IPC as-built to put the temps on the gauges. When I select IPC and "start", I get a dialog box that says the feature should only be used to program the odometer when the instrument cluster is replaced. Selecting "OK" opens a new box with miles/km selection, and the next box allows a number input. I tried this twice and cancelled out of it both times.
The as-built never opens. Is this expected or am I doing something wrong?
2023 Lariat and I'll get the Sync version shortly....
