2023+ Super Duty ForScan Spreadsheet
#62
Anyone know anything about what may need to be done in ForScan if i replace my 2024 Lariat Reflector LED headlamps with the Projector Style that come on the Platinum trims?
I am trying to figure out how to get the Autoleveling feature to work, and possibly if i can enable to the lights to adjust based on steering input as well.
#63
TESTER needed DTE w larger tank
Thanks to @sbechtold for reporting back.
I need some who has installed a larger tank to test.
shoot me a PM
ZooDad
shoot me a PM
ZooDad
#64
i just made some changes to my truck.
i can confirm that values from '22 spreadsheet for disabling door ajar chimes does work. IPC 720-01-02 xx0x xxxx
also disabling triple ding at start up does work
for enabling climate screen at bottom of sync screen: it does work, however, i could not get cooled/heated seats, nor heated steering wheel on climate bar to work.
when adding the climate functions to the screen, all the other function buttons are replaced. i did not like that so i put it back to stock.
also my truck would not remove the reverse black box.
my truck is '24 Lariat Ultimate with a 12/23 build date. current sync software is higher than rev 902.
#65
The following 3 users liked this post by GeneS.:
#66
#67
Maybe, its not the black box in the 360 camera top down view, its the black box when your driving and using the cameras.
#68
#69
@ZooDad
I updated my 24 turn signal flash today and the spreadsheet values gave me an error, so I did it using the plain English and for 7 flashes the as built data was updated to xxxx-1cxx-xx when I went back to check,
I also got the global close to work using the plain English and enabling all global lines in the BCM, DDM and PDM.
but now my reverse alarm sound in the cabin has changed to a cheaper annoying almost back up outside alarm sound. Any thoughts to why that is? Or how to change it back?
It did tell me it went into battery saver mode, I left headlight on whilst I was playing with this….. could that have caused it? I was able to write everything with no issue. Thoughts?
edit, after a few minutes sitting and restart, it now sounds the same as it did…. I guess the batter saver reverts to a cheaper “dinger”
#70
@camperfanatic01
What error did it give you in AsBuilt?
No idea why your chime tone would change.
I would restore your backup and start over to determine the cause.
ZooDad
ZooDad
#71
@camperfanatic01
ZooDad
ZooDad
error was a checksum and it couldn’t write it. I didn’t take a pic and don’t remember the exact wording.
#72
ZooDad
#73
got it, thanks…. It’s a little scary the first time…. lol.
thanks for all the help with this on this forum and others!
#75
Good to know you can edit through plain English. I'm getting the S&B tank installed tomorrow. Already contacted ZooDad to help out but good to have the easy edit as a fallback if other methods don't work.
