2023+ Super Duty ForScan Spreadsheet
#211
#212
It’s a bug I think.
I have the same experience on my MY24 F350. As soon as I exit Waze (or the built in Ford Nav) the Diesel Measurement (and General) numbers show up. I enabled Nav in HUD recently. I did not set Bambi mode, key fob panic button 2 clicks or remove black box in reverse. My courtesy wipe has only ever worked on the lowest setting on the wiper stalk. I just went and disabled "Nav in HUD" and I still don't see Diesel or General Measurements when using Nav.
It would be really nice if someone (that hasn't changed the Nav in HUD settings) can let us know if you can see the Diesel Measurements when in Tow Mode and you have a destination programmed into your Nav (Ford or Android).
#213
#214
The following users liked this post:
#215
#216
Does anyone know if the Glare free lights work, this is from the 2021 F150 forscan sheet? I makes your high beams gently brighten and dim instead on instant on and off, it’s also supposed to cut/block the light around on coming traffic so the high beam doesn’t blind them.
#218
I have a ‘24 350 Platinum. I didn’t know it has a name, but my truck dims the high beams up and down when it’s left to auto. When flicking the high beams manually, it’s normal.
#219
Can you be a little more specific what camera view and what is the black box doing there what happens when it is removed? I just made three changes to my 24my
1) nav in hud and it is working fine now
2) Bambi light and also fine
3) removed black box but have no clue what it is please be detailed in what.
Also when Ford "talks to my truck every couple of weeks will any of these get changed back on me or will they stay put.
#220
#222
#223
Interesting question. As it stands now with the truck phones home it does not change established AsBuilt files UNLESS it is over writing a module, which to my knowledge has not happened yet. I have heard of Body Control Modules (BdyCm) being updated OTA.
Also I do know that when the truck phones home it will upload your AsBuilt. So when you go to Motorcraft service.com to get your factory AsBuilt it may not be your original factory AsBuilt.
ZooDad
#225
Has anyone tried anything crazy yet on the 23/24s like attempting to add heated wheel on an xlt, adaptive cruise, or auto climate control or hud? Didn’t get a single hit when searching. I’m looking at a 24 xlt, I normally go lariat but I kind of want a cloth truck and not so much black on the interior after 6 trucks of that variety. Just curious if I can do this for more or less than lariat ultimate lol.
