2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
2023+ Super Duty ForScan Spreadsheet
Old 02-24-2024, 10:09 PM
kylant's Avatar
kylant
kylant is offline
Originally Posted by roadkillbbq
Success!! I have successfully restored the display of Nav data (turn by turn instructions, etc) over the HUD system in my 2024 F350 Lariat w/Lariat Ultimate Package !!!
APIM As Built Address and Configuration Register Values
7D0-05-01 2586 0400 008C
Made this edit:
7D0-05-01 x6xx xxxx xx—
Resulting Address and value:
7D0-05-01 2686 0400 008C
I cycled the ignition, then after the infotainment system reinitialized, I reset the APIM by pressing and holding the audio power button (i.e. the volume "off" ****) and the forward seek button (>>| ) simultaneously.
Now, the Nav data is displayed on the 2024 F350 Lariat w/Lariat Ultimate Package HUD like it used to be for my early 2023 F350 Lariat w/Lariat Ultimate Package!!! Yay!!
100% of the credit goes to ZooDad who investigated on his own time and after I sent the 2023 and 2024 F350 As-Built Data from Ford, was able to tease out what needed to be changed. Thanks a lot to ZooDad!
Late edit: I can also confirm that Google Maps and Waze also once again display their Nav instructions over the HUD via Android Auto. I don't have an Iphone so I can't test that functionality, but I imagine that will work too.
hum...
my as built for that line is:
7D0-05-01 2186 0400 0088
'24 F250 lariat ultimate 7.3
  #137
Old 02-24-2024, 11:10 PM
ZooDad's Avatar
ZooDad
ZooDad is online now
@kylant
Does your nav display to HUD?
ZooDad
  #138
Old 02-25-2024, 11:14 AM
kylant's Avatar
kylant
kylant is offline
Originally Posted by ZooDad
@kylant
ZooDad
no, it does not
  #139
Old 02-25-2024, 01:51 PM
ZooDad's Avatar
ZooDad
Originally Posted by kylant
no, it does not
@kylant
try this change
7D0-05-01 x2xx xxxx xx- -
ZooDad
  #140
Old 02-25-2024, 05:05 PM
kry226's Avatar
kry226
kry226 is offline
Interesting. My as-built for 7D0-05-01 is 2286 0400 0089 and I have nav in the HUD. I've never lost that function and I'm pretty sure I'm up to date on all the OTA updates.
  #141
Old 02-25-2024, 06:15 PM
blueflame2015's Avatar
blueflame2015
blueflame2015 is offline
Goals:
*LED reflector head lights to LED Projector head lights with auto level and turning
*I'd also like to change the tails from partial LED to FULL Led.
*Power step operation one side at a time
*Power generator default to Off on start up
  #142
Old 02-26-2024, 06:52 PM
Ron Hill's Avatar
Ron Hill
Ron Hill is offline
2023 Tremor 60 Gallon S&B
Hello,
just installed a S&B fuel tank and changed the value from stock 34.1 with forscan to 60. DTE went from 420 to 680. Does that sound right, thinking it should be closer to 800 DTE
  #143
Old 02-26-2024, 07:22 PM
System's Avatar
System
System is offline
Prolocutor
Received 1,204 Likes on 578 Posts
Originally Posted by Ron Hill
Hello,
It will take miles to update. I did the same with my 2017 when I went to a 55 gallon Titan. Made the change with Forscan and it wasn't much of a difference in DTE. After a few hundred miles, it corrected itself. I was worried for a while but other members who did the same told me to wait it out and it corrected in time.
  #144
Old 02-26-2024, 09:28 PM
ZooDad's Avatar
ZooDad
Hello,
ZooDad
  #145
Old 02-26-2024, 10:24 PM
Peej11's Avatar
Peej11
Peej11 is offline
Hello,
Drive a bit and it will trend upwards for a while. I just did my second fill up and it shows ~825 on the gauge at full now on my ‘24 6.7
  #146
Old 02-27-2024, 09:46 AM
Ron Hill's Avatar
Ron Hill
Ron Hill is offline
Seems to be improving, hopefully on the 2nd fill up the range increases. Driven about 50 miles for far and the mileage is increasing.
  #147
Old 02-27-2024, 05:59 PM
rhw1964's Avatar
rhw1964
rhw1964 is offline
Folding mirrors
Line 8 of the 23/24 Super Duty spreadsheet date 2-24-24 is labeled Autofold Mirror Lincoln Style. In column "E" it has xx*x but doesn't say what to change the "*" to. Anyone have any info on what the change number or letter is for that column?
Thanks,
Mike
  #148
Old 02-27-2024, 06:08 PM
ZooDad's Avatar
ZooDad
Thanks,
Mike
Its fixed
ZooDad
The following 2 users liked this post by ZooDad:
  #149
Old 02-28-2024, 06:23 AM
rhw1964's Avatar
rhw1964
rhw1964 is offline
Its fixed
ZooDad
thank you I appreciate it
  #150
Old 02-28-2024, 07:41 AM
saratoga2011's Avatar
saratoga2011
saratoga2011 is online now
Probably a dumb question.
I was attempting to modify the IPC as-built to put the temps on the gauges. When I select IPC and "start", I get a dialog box that says the feature should only be used to program the odometer when the instrument cluster is replaced. Selecting "OK" opens a new box with miles/km selection, and the next box allows a number input. I tried this twice and cancelled out of it both times.
The as-built never opens. Is this expected or am I doing something wrong?
2023 Lariat and I'll get the Sync version shortly....
Quick Reply: 2023+ Super Duty ForScan Spreadsheet
