Chimes, need hammer
Old Jan 25, 2024 | 05:22 PM
MeTo's Avatar
MeTo
Chimes, need hammer
Turn ignition off, key in ignition, doors closed and I'm sitting in seat. I get six double dings. Is it possible to disable that? Is that 'feature" the key in ignition reminder? It shouldn't be, I didn't open the door.
Old Jan 25, 2024 | 05:56 PM
4wd6.7L's Avatar
4wd6.7L
What year is this truck and you aren't seeing any notice on the display that accompanies the chimes?
Old Jan 25, 2024 | 06:01 PM
JoeUser's Avatar
JoeUser
I usually get those chimes when the door is open and key left in the ignition. Sounds like you might have a door switch that's bad?
Old Jan 26, 2024 | 06:25 AM
MeTo's Avatar
MeTo
Thanks, I will check if the interior light works properly with the drivers door?
Old Jan 26, 2024 | 08:53 AM
MeTo's Avatar
MeTo
Truck in sig and no notices.
Interior lights turn on when driver's door is opened. The door switch appears to operate fine.
Old Jan 26, 2024 | 10:37 AM
HarveyTruck's Avatar
HarveyTruck
This may or may not help. The other day when I shut my truck off it wouldn’t quit dinging at me. I started it back up and off twice to no avail. I finally figured out my headlights had been switched from auto to on and being daylight I didn’t notice it. Turned them off and problem solved. I didn’t see a warning message on the display which would’ve been helpful, it warns me about everything else! I suppose if I’d left it the headlights would’ve timed out and shut off eventually or I’d seen it after dark.
Old Jan 26, 2024 | 10:46 AM
JoeUser's Avatar
JoeUser
I'll bet you that's it. I've bumped that **** with my knee a few times getting into the truck, and yeah, it's dinged the chimes. I just totally forgot about that, lol
Good catch!
Old Jan 26, 2024 | 10:52 AM
MeTo's Avatar
MeTo
Headlights are off. I was hoping that was it.
Old Jan 26, 2024 | 12:27 PM
MeTo's Avatar
MeTo
I think I have it resolved? I disabled the key in ignition parameter in the IPC module. It does not ding when I turn the ignition off and the key is in the ignition. It dings if the light switch is on and I open the door and it will ding if I turn the ignition off, leave the key in and open the door. So, I think all is as it should be. Knock on wood.
Old Jan 26, 2024 | 12:38 PM
JoeUser's Avatar
JoeUser
While you were in that module, you didn't happen to come across a setting to manage that dang Collision Avoidance pop-up whenever starting up, did you? LOL
I've got that feature turned off, but it always shows up when I start up the truck... argh. It's not enough to just turn it off, but to be nagged about it every single time I drive is ANNOYING
Old Jan 27, 2024 | 10:07 AM
MeTo's Avatar
MeTo
No, I was on a mission and trying not to distract my ADHD brain..
argon
Jul 13, 2020 08:49 PM
KenRebF-250
Nov 7, 2016 03:28 PM
Ford_NDN
May 20, 2010 08:44 PM
Vin_Man
1997 - 2003 F150
Dec 1, 2003 11:56 PM
