215 miles on my new 2024 350 Plat. Noticed couple things while looking under the hood at the power steering hose/clip some are having leak issues with.
1./ One of the two hoses connected to the antifreeze reservoir has no clip on it. Low pressure not requiring one or just plain missing?
2./ Spotted a lubricant mark at the black plastic cowl right neat the brake fluid reservoir. Sticky to the touch. No residue around the brake fluid cap.
3./ Just below the fluid mark (yellow circle) is a threaded hole (red circle). Do you have that not in use as well or am i missing something that's supposed to be attached there? Added another pic couple posts below this one with coloured circles.
Can someone with a 2024 take a look to compare please?
You worry to much, close the hood and enjoy your truck!
That supposed to help me? This is not s $ 9999.99 Lada, but rather a $ 126,565 CAN, plus 13% Tax, most expensive vehicle i ever bought. Damn right I'm gonna worry. Thanks for your input.....
yes it was meant to help you, maybe prevent a heart attack! But whatever you want, carry on!!
after all buddy it’s a ford!!!
if you are that worried have it towed to the ford garage.
Thank you very much! The type of helpful answer i was looking for. Just for that, I'll set you up with a X-Pin, should you ever need or want one down the road.
Thank you! No problem, glad to assist. I've asked a lot of questions and would have the same issue when something looks incomplete. There was an issue with RAM TRXs missing a bolt on a shock setup for the rear diff so there's certainly the chance the factory can miss a bolt, clip, etc. There were so many issues with the TRX they created a delivery checklist on the forum :-) Ford is no different.
