Whining noise????
Old Jan 22, 2024 | 04:30 AM
leonharu's Avatar
leonharu
Bob,how difficult is for you to pull up the center floorboard plate and drive it so you can maybe tell if it is the transmission?I guess the gas pedal may be a problem?
Old Jan 22, 2024 | 07:49 AM
oscar1955's Avatar
oscar1955
From your description I would suspect the noise is coming from the rear axle. Put the truck up on jack stands and have some one operate it in gear and run it at slow speeds. Apply the brakes lightly to put a load on the rear end try to duplicate the noise.
When up on stands check pinion gear for movement in and out of the housing where drive shaft bolts.
If you drain the fluid, drain it over a magnet to check for metal contamination.
I would suspect you have a pinion bearing issue.
Old Jan 22, 2024 | 08:03 AM
BobM1949's Avatar
BobM1949
Ok. Thanks so much!
Old Jan 22, 2024 | 08:40 AM
52 USCG Panel's Avatar
52 USCG Panel
I have a 4 speed non-synchro, and it whines for sure. The distinctive sound can be heard for quite a distance (there's in fact a story Bob Jones and I like to tell about that very thing). If your 3 speed is a non-synchro transmission, and the sound you are hearing isn't something new, I'd say you may not have an issue. The whine could just be part of the charm of driving an authentic old truck and something to be embraced rather than feared.
Jim
Old Jan 22, 2024 | 08:44 AM
BobM1949's Avatar
BobM1949
K. That’s interesting. I guess im ok with it as long as the tranny isn’t getting damaged by it. Lol
Old Jan 22, 2024 | 08:54 AM
bobj49f2's Avatar
bobj49f2
I have the non-synchro transmission in my stock '49 F-2 and tend to get a whinning noise every so often.
It seems to only happen when my wife is in the truck
maynard1978
2015 - 2020 F150
Jan 31, 2020 01:19 AM
dmm50
Modular V8 (4.6L, 5.4L)
Dec 30, 2010 12:08 PM
79superduty
Jul 28, 2007 07:28 AM
jonnysteals
2004 - 2008 F150
Mar 22, 2006 03:15 PM
