burning smell
Old Jan 18, 2024 | 03:22 PM
GMB Racing's Avatar
GMB Racing
burning smell
I got a burning smell from my truck last night after remote start and It does have one every now and then as I turn the heater controls, 2021 f250,
the only thing different between normal start and remote start id the rear window and mirror heaters come on Any thoughts?
Old Jan 18, 2024 | 03:51 PM
4wd6.7L's Avatar
4wd6.7L
How long was it idling before you got to the truck and noticed the smell? Or is this an inside the cab smell, not outside?
Old Jan 18, 2024 | 04:52 PM
GMB Racing's Avatar
GMB Racing
inside cab smell Smell like electrical Resistor burning
Old Jan 18, 2024 | 06:41 PM
speakerfritz's Avatar
speakerfritz
If I let my truck sit at high idle for 20 to 30 minutes I get a burning smell which is the dpf cooking soot
Old Jan 20, 2024 | 03:52 PM
Tre900's Avatar
Tre900
4wd Low
I have a 2022 XLT F250 6.2L 6r100. I also recently smelled something like burning plastic. It was worst when I had my doors open. Wife noticed first on passenger side. It was cold, I had been driving for over an hour 30 minutes. I had used "Slippery" mode and wrote it off as maybe 4x4...and later read that Slippery mode doesn't activate 4x4. Does any of that sound the same as your cases? I'm close to 10k miles fwiw.
Old Jan 23, 2024 | 12:36 PM
Ford Motor Company's Avatar
Ford Motor Company
Official Ford Pro Rep
Hi there. Feel free to send us a DM with your vehicle's VIN and mileage. We'd be happy to look into this for you.
Old Jan 23, 2024 | 05:15 PM
BigBlue22's Avatar
BigBlue22
I also got the burning electrical smell today. Got the smell through the vents, but also noticed it when I got home from under hood. 22’ 7.3 going to keep an eye on it, I’ll see if it does it again in morning.
Old Jan 24, 2024 | 10:06 AM
kmcconahay's Avatar
kmcconahay
3rd Gear
Sme burning smell
2017 F-350 King Ranch 6.7, last week same issue with auto start and cold outside, what I found after much searching look under passenger seat and found the ground wire going into a module or whatever its called(Part# GU5T-14B663-AA) was melting HOT so turned off the seat heaters and it cooled down. The plug is melted and wont unplug.
Old Jan 24, 2024 | 10:14 AM
CBEllis's Avatar
CBEllis
I agree w/ @speakerfritz above. This past weekend when we had a colder front in TX, I remote started the truck several times. The automatic high-idle kicked in and it was noticeable (sound) to have the truck idling at 1k RPM. And depending on the wind, the smell of the DPF burning can get trapped under the bed, under the truck, and waft up through the engine compartment. It can also leak into the cab if the heat / defroster is blowing during a remote start, especially if the HVAC system is taking in outside air (which it usually does during heating/defrosting). I think you're smelling a normally operating system.
Old Jan 24, 2024 | 12:42 PM
GMB Racing's Avatar
GMB Racing
just one thing I have a gas job
SMarquez
Aug 20, 2022 02:30 PM
fyrmnk1
Feb 2, 2020 06:59 PM
spud57
Dec 10, 2013 01:59 PM
jermort
6.7L Power Stroke Diesel
32
Nov 16, 2010 12:19 PM
finelinesp
Dec 5, 2005 09:23 PM
