Glass fuses
Old Jan 16, 2024 | 08:37 PM
EBaade's Avatar
EBaade
Trailering
Glass fuses
Hello, classic group!
Eventually we will upgrade to a modern fuse box but in the meantime can anyone recommend places to locate specific size/amp glass fuses?
I have the owners manual so I can see the amp and approximate size needed.
local auto parts stores were no help. Nothing in LMC.com either.
1978 F150 Ranger.
Thanks!!
Old Jan 16, 2024 | 08:47 PM
Viper Pilot's Avatar
Viper Pilot
Cheap Chinese crap I’m sure but they should get you through.
Amazon Amazon
Surprised the parts store didn’t have anything. A local Mom and Pop hardware store might be your next stop.
Old Jan 16, 2024 | 08:48 PM
tbear853's Avatar
tbear853
Our several Advance Auto Parts stores carry them. I also carry spares.
Old Jan 16, 2024 | 09:10 PM
Red Mercury's Avatar
Red Mercury
The old glass tube fuses can be a challenge. Believe it or not, there are industry standard designations (3 letters) and it helps a ton if you know what to ask for. NAPA or any other parts chain store staff are not usually helpful unless you give them a number. The fuse rating isn't enough because there are different lengths which is usually the biggest problem. Ford dealers used to carry all the sizes you would need for your truck but I haven't bought one there in decades. Here is a link that shows the different fuse sizes Glass and Ceramic Tube Fuse Catalog Numbers. For example your radio fuse is a 7.5 Amp fuse and if my memory is correct it is 7/8 of an inch in length. If you go to the table you will find the catalog number is SFE-7-1/2 (or SFE-7.5). If you search on NAPA's site or most sites for SFE-7.5 you should be able to find it and then go to the store with their part number. They might have to order your fuse or bring it from a warehouse. Many parts counter employees don't know the ins and outs of glass fuses and they tend to direct you to what's hanging on the rack. Even googling SFE-7.5 will give you some hits. This applies to any fuse. The old fuse box in our trucks is okay if you know how/where to get the fuses. I keep a stock of most sizes and it actually doesn't cost too much to have some on hand. I hope this helps.
Old Jan 16, 2024 | 09:40 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 most normal auto parts stores carry them. Have you tried a Farm and Ranch store like TSC (Tractor Supply Company), old school hardware store like Ace or Ture Value Hardware? Hit up your local BIG truck, truck stop.
“The bitterness of poor quality lingers long after the sweetness of low price is forgotten.” Just saying.
Parts Vendors & Resources
Dennis Carpenter Ford Restoration Parts
National Parts Depot:Ford Truck Parts & Accessories | 1948-1979
MAC's Antique Auto Parts
Blue Oval Truck Parts
Jeff's Bronco Graveyard
The Early Ford Store-San Dimas,CA
Truck & Car Shop (Orange, CA): 48-86 Ford Trucks, 66-86 Ford Bronco
C&G Early Ford Parts: 32-79 Ford Trucks (Escondido,CA)
Sacramento Vintage Ford
Flashback F-100s: 48-2008 Ford Truck Parts
Vintage Pickup Truck Parts & Restoration Resources Directory
Green Sales Company - Vintage NOS & OEM Parts
Old Jan 17, 2024 | 01:45 AM
TheGreatPumpkin's Avatar
TheGreatPumpkin
The problem I found is that unless you specifcally have it ordered some of the fuses you can only get 1 of from a multi pack for 5 bucks at O'Reily's, Autozone etc., Then you end up with a bunch of fuses you have no use for. You can get them at ACE or Do it Best but the mark up is insane. If you have time get I think you can get them on Digikey. This makes troubleshooting very difficult when you keep popping fuses. Could always stick a .22 shell in there...
Glass fuses are actually still largely used in Commercial low voltage boards for fire alarm, security panels, HVAC boards etc. Open your furnace up at home and I bet it'll have 2-3 on the board.
I gutted my fuse box as it was too rotten to save. I can mail you all of my glass fuses if you want as I have installed two blue sea panels.
Old Jan 17, 2024 | 08:31 AM
FuzzFace2's Avatar
FuzzFace2
When looking for a short get a breaker of the same size and wire it in while hunting for the short.
If you put a test light between the breaker and panel you can then look when it is sending power (light on) or it tripped (light off)
Dave ----
Old Jan 17, 2024 | 10:49 AM
DirtyFerd's Avatar
DirtyFerd
CJ Pony parts is just one place where you can get glass fuse adapters.They allow you to plug in a modern spade type fuse
Old Jan 17, 2024 | 10:56 AM
TheGreatPumpkin
Unless your terminals are disintegrated, missing and a quarter the block is melted like mine LOL.
wavetrain75
41
Oct 14, 2025 11:02 AM
4B11TX
Oct 19, 2021 07:03 PM
79F150Seattle
Aug 15, 2011 05:29 PM
Jordan M
Electrical Systems/Wiring
Jul 10, 2010 04:26 PM
lilbob1131
Apr 25, 2005 02:10 AM
